I'm trying to connect to the RS485 of my stove/furnace and it has a strange connector for this. I want to intercept the existing physical connection, so I need both plug and receptable.
Plug (each pin ~4x4 mm, total ~8x8 mm):
Plug of the Connection
Receptacle (Outside dimensions: 9.5x9.5 mm):
Receptacle of the Connection
It actually looks like a Molex Minifit connector, but it is not really. The size fits exactly, but the 2x2 Molex Minifit Connection has two rectangular holes and two trapezoid holes. This connection I have here only has one trapezoid hole.
I actually bought 2x2 Molex Minifit connectors and they don't fit. I also checked the Molex Microfit and they also don't seem to be the right thing.
How is this connector called and where can I buy a plug and a receptacle? Or, even better, where can I buy an extension cord (1:1 mapped) so I don't have to crimp my own cable?
    \$\begingroup\$ There are many equivalents; you may find something of use from major manufacturers (TE, Samtec, etc.); it may also be a custom-keyed Mini-Fit (or equivalent), which will be much harder to find. \$\endgroup\$ Aug 24, 2022 at 14:25
  • \$\begingroup\$ Molex Mega-fit? \$\endgroup\$
    – winny
    Aug 24, 2022 at 19:15
    \$\begingroup\$ Look at the plug REALLY REALLY REALLY close .. If you're lucky, and you get the right light angle, you may see a part number or a manufacturers name at least. \$\endgroup\$
    – Kyle B
    Aug 24, 2022 at 20:27
  • \$\begingroup\$ also mini-fit has square pins and this has round pins. \$\endgroup\$ Aug 25, 2022 at 11:45
That looks like a TE Mini-Universal MATE-N-LOK. The good news is that inline receptacles exist, so you can make an extension cable the "right" way. The bad news is that it doesn't look like pin-to-socket jumpers exist and the crimper is $850.
Edit: there are also tap splices that will give you a clean pickoff if you can access the individual wires going into the plug.
  • \$\begingroup\$ I just wanted to say that I checked and this answer is indeed correct. \$\endgroup\$ Aug 24, 2022 at 20:51
