Considering any transfer function H(s), is there any meaningful way to use the s-variable singularities to obtain the f-variable ones to trace the Bode plot?
I know direct conversion with \$ s = \alpha + j\omega\$ makes no sense, but why does it work at times? I assume it's just coincidence, can anyone think of an example in which it doesn't?
Examples
\$ H(s) = \frac{R}{1+sCR} \;\$:
\$s_p = -\frac{1}{RC} \rightarrow f_p = \frac{1}{2\pi RC}\$
\$ H(s) = \frac{1+sRC_1}{s(C_1+C_2)} \frac{1}{1+sRC_{eq}} \;\$ where \$ \; C_{eq} = \frac{C_1C_2}{C_1+C_2} \;\$:
\$ \quad s_p = -\frac{1}{RC_{eq}} \rightarrow f_p = \frac{1}{2\pi RC_{eq}}\$
\$ \quad s_z = -\frac{1}{RC_1} \rightarrow f_z = \frac{1}{2\pi RC_1}\$
Edit: my bad Tim, english is my 2nd language and I'm not extremely familiar with these topics, I'll try to provide more context.
I was given a certain transfer function, of which I need to find zeros, poles and Bode plot.
Finding the zeros and poles is easy using the Laplace variable, and I know I can find the corner frequencies of the Bode plot by using \$ H(j\omega)\$.
My question is, why do the corner frequencies of the Bode plot match the Laplace variable singularities when there is no direct correlation between the 2?
E.g. why do these have the same 'form'
\$s = -\frac{1}{RC} \rightarrow f = \frac{1}{2\pi RC}\$
When this obviously doesn't work?
\$ s = -\frac{1}{RC} \rightarrow \omega = -\frac{1}{jRC} \rightarrow \omega = \frac{j}{RC} \rightarrow f = \frac{j}{2\pi RC} \$
