I have the following circuit to measure the UV A power with an OpAMP, a photodiode and an ADC:
I have simulated the circuit in CircuitLab and it looks okay, but I want to hear some additional feedback about the component selection to be sure that the circuit will work as expected. The circuit should output ~+150 mV when the max UV A power of 6 mW is measured by the photodiode and ~1.65 V when no light is available. The whole circuit is powered by a single 3.3 V supply.
Does this circuit fit into my requirements or does it contain an error?
  • \$\begingroup\$ I'm guessing that CircuitLab either doesn't take diode capacitance into account, it doesn't take op-amp bandwidth into account, or both. I expect that in real life it'll oscillate because of the diode capacitance handing off of the op-amp's inverting input. If so, you'll need some capacitance in parallel with R6 to stabilize it -- and that will slow down your circuit. \$\endgroup\$
    – TimWescott
    Aug 27, 2022 at 14:53
  • \$\begingroup\$ Can you show your design equations, so someone checking doesn't have to look up all the relevant numbers? \$\endgroup\$ Aug 27, 2022 at 15:01
  • \$\begingroup\$ it depends on your specs for tolerance errors from 3.3V and R values. You can eliminate IC6B by inverting the diode with a single supply as it maintains 0V across it with a positive output at 3V/6mW/cm^2 \$\endgroup\$ Aug 27, 2022 at 15:01
  • \$\begingroup\$ The 1st error is lack of design specs for sensitivity, and range tolerances. Do you really want 0 at Vdd/2? Do you know std. R Values are 2.70 and 2.74? Do you have any other requirements for noise? rail-to rail? . Also it is power density in mW/cm^2 Other than the inverted diode voltage, and C ratio gain effects, the component choice of the diode is correct. \$\endgroup\$ Aug 27, 2022 at 15:36
    \$\begingroup\$ Thanks for your comments. I have updated my question \$\endgroup\$
    – Kampi
    Aug 27, 2022 at 16:18
That means the op-amps are also powered by the same voltages; 3.3 volts and 0 volts.
It won't work because the photocurrent of the photodiode will try and raise the virtual ground of the first (left hand) op-amp and, the output of the op-amp would have to produce a negative voltage (lower than 0 volts) to keep the virtual ground at 0 volts. This can't happen without the op-amp having a negative power rail: -
But, you could turn the photodiode round and that stands a chance of working. And, you probably don't need the 2nd stage op-amp either.
Well, your requirements are somewhat defined by what the simulation tells you is produced and, given that this looks unlikely to be correct, I don't think your requirements are very well defined.
And, as Tim Wescott points out in a comment, you will probably need a few pF across your feedback resistor to cut-down on noise and instability.
  • \$\begingroup\$ Thanks. I have updated my question. \$\endgroup\$
    – Kampi
  • \$\begingroup\$ @Kampi once an answer is produced, you cannot just incorporate the good information it gives you and reformat your question. I'm going to roll-back your question to where it originally stood. I also suggest that if you are recognizing the info in my answer as useful, you upvote it. \$\endgroup\$
    Aug 27, 2022 at 16:22
  • \$\begingroup\$ If you are going to do anything to your question you need to do it carefully so it doesn't make my answer look wrong. If you have a new train of thought given what I have said in my answer then please mention it in a comment and I'll find a way of revamping your question with this new information whilst keeping the original question still current and therefore, my answer still current. \$\endgroup\$
    Aug 27, 2022 at 16:26
  • \$\begingroup\$ Thanks. I rotate the diode to remove the negative current and remove the second OpAmp. \$\endgroup\$
    – Kampi
    Aug 27, 2022 at 16:29
  • \$\begingroup\$ That's a good start and, I seem to remember that your modified question mentioned +/- 2.048 volts but, without a negative and positive power rail, this can't be done. \$\endgroup\$
    Aug 27, 2022 at 16:32
