I would like to use Wireshark to watch the communication between my device and the server. I basically need an Ethernet hub to deploy the environment of testing. My trouble is that Ethernet hubs are almost deprecated and replaced by Ethernet switches. It's hard to find an Ethernet hub.
So, my question is:
- How can I configure an Ethernet switch into a hub? What kind of Ethernet switch can be used?
- Is there any other way to deploy the test environment so that I can run Wireshark to watch the communication between my device and the server?
