I have to determine the relationship between Vout and Vin. When analyzing the circuit I realized it was quite similar to a non-inverting op-amp circuit. I know from my past homework that I can calculate Vout in the following way: $$V_\text{out} = (1 + R_2/R_1)V_\text{in}$$ This ends up giving me: $$V_\text{out} = (1 + 9\text{ k}/1\text{ k})V_\text{in} = 10V_\text{in}$$
However, to use this formula I had made the assumption in the past that \$V_{+} = V_\text{in}\$. But now there is a resistor in front of the positive entrance, so I do not think this still holds true.
However, I am not sure what value I'd give it now. I think I have to use the 5 V power source to decide this, but I also get the feeling it will have an effect on the negative side, but I do not know what sort. Any tips or hints to get me to the right direction?
