I'm trying to simulate a full wave bridge rectifier circuit with the capacitor filter. The alternating voltage supply is 30 V at 50 Hz.
The peak value for the voltage across the load is 28.5 V. However, I don't get how that's possible. Is it the RMS voltage or the average voltage across it?
After increasing the load to 30 kΩ, I tend to get the same plot as before. I'd expect the graph to smoothen out as the rate of discharge has decreased due to a rise in load resistance and hence the time constant should increase but this has clearly not happened.
