8
In the picture below, what are the weird symbols over the switches? I've circled or pointed to them with red.
  • \$\begingroup\$ Do you have a part list or model number for s1? \$\endgroup\$
    – Passerby
    Commented Sep 10, 2022 at 4:29
10
The dashed line represents a mechanical instead of electrical connection.
On a push button like s2 s3 s4 it's a redundant symbol.
S1 is a Emergency Stop NC Turn Reset type switch. It needs to be twisted to reset if pushed. The dash line, the z bar, and the dip represent this.
The D represents the mushroom head of the switch.
The Z is the twist action. If it was a ] bracket it would be a pull to reset. [ would be pushed to reset. There is also switches with key reset, represented by a keyhole.
Unsure what the block represents.
The V notch is the latching.
And Normally Connected switch symbol is because it is closed when not pushed.
Try these: -
There are more explanations on the site where I took the image.
  • S1 is a latching rotary activated switch
  • S2 is a momentary action push-button (normally open)
  • S3 is same as S2
  • S4 is same as S2 but normally closed
