I found this device here on the site.
I need something to switch to a 9 V backup battery when there is a 48 V phantom power outage.
How can I change the FET to switch OFF the BAT1 (9 V) backup battery when the main V1 (48 V) is on?
  • \$\begingroup\$ I think, you must just exchange V1 (your 48 V) and BAT1 (your 9 V), remove R1 from the gate side and add a 100 kom resistor to GND at the source side. \$\endgroup\$
    – Jens
    Sep 14 at 20:40
  • \$\begingroup\$ Thanks @Jens! Can you recommend a FET in a small size? the maximum current consumption is max 15mA. \$\endgroup\$
    – Tomi
    Sep 19 at 4:33
  • \$\begingroup\$ In this case you need only two diodes to separate the supply voltages if it is acceptable to lose 0.5 V per path. \$\endgroup\$
    – Jens
    Sep 19 at 11:40
  • \$\begingroup\$ The goal is to make the voltage drop as small as possible in 9V path, 0.5 Volts is too much :( \$\endgroup\$
    – Tomi
    Sep 20 at 5:03
  • \$\begingroup\$ SEPTEMBER 22ND It would be useful if the downvoters explained why this question "needs details or clarity". I can understand what is wanted perfectly. As can Jens - given their answer. \$\endgroup\$
    – Russell McMahon
    Sep 22 at 16:14
If you cannot afford a diode drop on the 9 V side this will do:
D1 and D2 will lift gate and source to the same voltage if V1 is active. In this case M1 is off. TSM680P06 is an overkill here, but at least, it is available..
If V1 is offline the body diode of M1 will conduct and initially deliver 8.5V at the load. Via R1 the MOSFET can turn on and finally 9 V is delivered.
  • \$\begingroup\$ Thank You @Jens, this is a very elegant solution! \$\endgroup\$
    – Tomi
    Sep 21 at 15:41
  • \$\begingroup\$ THat hurts my brain in several ways - to my surprise. 0420 here - back to sleep. May look different in the (later) morning :-). I started to say it had issues several times but each time decided that I was wrong. \$\endgroup\$
    – Russell McMahon
    Sep 22 at 16:22
The original circuit will work well with one major modification.
The voltage from the 48V supply must be reduced (typically using a two resistor divider) so that the FET reverse gate voltage applied when the 48V supply is live is substantially less than Vgs_max for the FET.
  • \$\begingroup\$ Thank You for all answers! \$\endgroup\$
    – Tomi
    Sep 26 at 9:45
  • \$\begingroup\$ Upvoting answers that are useful is appreciated. (I have enough rep :-) - Jens may appreciate it). \$\endgroup\$
    – Russell McMahon
    Sep 26 at 10:36
