Electrical transmission lines can face various types of short-circuit faults, for example, line-to-ground, line-to-line, etc. How do power system engineers find the fault location by observing from the power station?
1\$\begingroup\$ Probably by finding the upstream fuse that blew. \$\endgroup\$– rdtscSep 13, 2022 at 19:21
1\$\begingroup\$ A Brief History of Fault Location in Transmission Lines \$\endgroup\$– StainlessSteelRatSep 14, 2022 at 12:44
\$\begingroup\$ Or reflectometry ... sending "high-speed pulse" into the line ... when the default is in the line ... \$\endgroup\$– Antonio51Sep 16, 2022 at 8:16
