6
My question:
  • How do grid and transmission line operators regulate the amount of power flowing in their networks, both to utilize the network optimally and to enact delivery policies like those in the examples below?
All the following is clarifying material that I've provided to explain what lead me to ask this question.
In newscasts discussing the electricity market, one often sees articles that involve language such as:
  • A new transmission line is being built from country A to country B, which will increase country B's ability to import electricity from country A by X MW.
  • Electricity prices in (say) Northern Europe are on the rise because power companies there prefer to export their electricity to (say) Central Europe where there is a high demand and therefore better prices per MWh, leaving their home markets with less supply.
  • Because of [powerplant maintenance / low hydro reservoirs / declining foreign relations / whatever else the reason], country A will reduce its electricity exports to country B by Y MW.
  • Electricity prices vary greatly from region to region in country C because most of the generation happens in a different region than most of the consumption, and transmission capacity between regions in that country is inadequate.
Such news can easily give an impression that electricity is like any commodity that can be transported in arbitrary quantities at will, like you'd export or import grain, oil, or cars, or control how much you water your lawn by turning on the garden hose tap. Anyone who knows something about power grids, however, knows that this impression is wrong: generation and consumption must always be kept in balance, and it's the consuming party that – by its actions that set up a certain impedance (that is, the load) in its part of the grid – determines how much power must flow into it from the producers, not vice versa.
Likewise, since the voltage and frequency must be kept constant, the producers and grid operators in between have to bear with whatever demand occurs within the consumer or, in case the load exceeds their technical or contractually agreed upon capacity, to disconnect. They are not at a position to say that "today we'll sell X MWh" or "tomorrow we'll cut our delivery to B by 50%" – not in a direct "hands on the water tap" way at least.
So I think the newscast examples above should be seen as statements of policy, instead of direct technical actions. However, obviously there must be some technical means to implement them in practice. What are they like? How do grid and transmission line operators regulate the amount of power flowing in their networks, both to utilize the network optimally and to enact delivery policies like those in the examples?
  • \$\begingroup\$ Edited to make question even more obvious. Cleared VTC. \$\endgroup\$
    – Russell McMahon
    Sep 15, 2022 at 11:40
  • \$\begingroup\$ Electricity is actually very much like water. If you have no pressure, you have no flow. If you have no voltage, you have no current. The difference comes from us having different tolerances for acceptable parameters in our homes. \$\endgroup\$
    – Abel
    Sep 15, 2022 at 13:41
First, your question is not solely a physics question, but it's also about policy and economics.
Apologies for the length of this answer, but this happens to be my daytime job and field of expertise, so I get a bit carried away.
There might be regional differences and some policies and pricing principles that I mention might differ a bit from country to country.
I'll address the different headlines first, then give some additional general comments.
This one is a simple statement of fact. The same transmission line will obviously also increase country A's ability to import electricity from country B by X MW.
One thing to keep in mind here is that one of these countries will often produce more than they need, while the other produces less. So the headline in country A will read:
A new transmission line is being built from country A to country B, which will increase country B's ability to export electricity from country A by X MW.
Also, many cross-country interconnections are DC, not AC. The converters at each side of the DC transmission line can determine the direction of the power flow. The direction of the power flow will (in general, but not always) be determined by the prices on each side of the cable.
This is both correct and wrong at the same time. This is not about physics but economics. In Europe, electricity is traded on Nordpool. All electricity suppliers say what they are willing to sell their electricity for, while all distributors1 say how much they want to buy the next day. This is supply and demand, and everyone will pay the price the "last" producer demands.
The Northern European producers don't sell to Central Europe, they sell the amount of power they get paid to produce. If it turns out that the producers in Northern Europe are willing to produce more electricity for the given price than domestic consumption, then there will be a production surplus, and power is exported.
Their home markets will only have less supply if the total energy is "fixed". This is the case for Norway, where the energy is stored as water in large reservoirs. If they produce more than the domestic consumption then they will "use up" the water they could otherwise have kept for later. This is not the case for wind and sun power plants for instance, as today's production won't affect tomorrow.
This has been done by some countries in Europe already, and many more are considering it due to the European energy crisis.
There are several ways to do this:
  • Open a breaker thus disconnecting a transmission line.
    • One less line = less power in total
  • Tweak the settings of converters on DC lines.
    • You can control the flow however you like.
  • Alter the power angle, thus controlling the power flow.
    • This is less common since it's not as simple in a dynamic system (well, it is, but a lot of equipment is old)
Europe is divided into "price areas". Some countries are divided into several price areas, due to "bottlenecks" in the grid. Norway for instance is divided into 5 price areas, and Sweden is divided into 4.
The reason why prices differ is that producers in one region are willing to produce a lot of power at a low price, leaving that area with a surplus. In a neighboring region, the producers demand a much higher price. The producers in the first region will produce as much as they can and the surplus will be transported to the other region. In an "ideal" grid, the prices in both regions would now be the same. However, the lines between the regions have limited capacity, meaning that even though the producers in the first region are willing to produce a lot of energy, they have to limit their production.
Now, remember supply and demand. The producers in the first region were willing to produce a lot of power at a low cost, but the demand wasn't high enough. They must limit their production to the regional demand plus the maximum export capacity. High supply and low demand give low prices.
The neighboring region imports as much as it can from the first. The rest must be produced in their own region at the price the producers demand. The price they demand is high, but the consumers are willing to pay the price. Low supply and high demand give high prices.
Side note: You might have heard of "bottleneck income". Bottleneck income is income the transmission system operators get when there is a bottleneck in the system. Remember that the producers in the first region were willing to produce at a low cost, and the price in the neighboring region was high. What happens is the producers in the first region sell their power for the price in their region, and the consumers in the neighboring region buy their power at the price in their region. The consumers pay more than the producers get paid. The surplus, called bottleneck income" goes to the TSOs.
You say:
They are not in a position to say that "today we'll sell X MWh" or "tomorrow we'll cut our delivery to B by 50%" – not in a direct "hands on the water tap" way at least.
Well, that is exactly what they say. We're willing to sell X MWh for y €/MWh tomorrow.
You are right of course. It's impossible to know tomorrow's demand. That's why there's a "flexibility market" where producers are willing to produce more or less power for a given price. The system operators will then "tell" certain producers to produce more or less power to maintain a stable frequency (power produced = power used).
The network is not utilized optimally when it comes to minimizing losses. It is a market optimization. The producers aim at maximizing their profits, while the system operators impose certain restrictions to maintain balance in the grid.
You can read more about grid balance here.
  • \$\begingroup\$ Perhaps worth mentioning that this ”The system operators will then "tell" certain producers to produce more or less power” process is called dispatch. \$\endgroup\$
    – winny
    Sep 19, 2022 at 6:53
When an authority has complete control over a network it is technically possible in a power grid to fully control the energy flow to a load and from each source. Simplistically, this is usually accomplished by adjusting the phase angle of alternators relative to their load. An alternator running at grid frequency and voltage can alter its output (or become a load) by phase angle variation alone.
Outages occur if the load exceeds the available or maximum acceptable energy provided.
This statement is "essentially wrong"
By controlling alternator phase relative to the supplied grid operators can control the amount of energy supplied. If a number of sources are involved and total capacity exceeds demand this allows the distribution of energy sources to be adjusted.
As well as management of the contribution of each energy source various fast and slower or slow response sources may be provided to provide energy.
How this is implemented in practice is complex with features such as spinning reserve, and fast response from battery, pumped hydro, flywheel, thermal storage, ... involved.
Much is available on this subject on the web.
A few starters:
Web search Spinning reserve - operating reserve
Peaking power plant / Peaking stirage here
Operating reserve Wikipedia
Peaking power plants Wikipedia
Flexible peaking resource
  • \$\begingroup\$ Generators do not have any capability to control their phase angle directly. They control input mechanical power. \$\endgroup\$
    – pdb5627
    Sep 19, 2022 at 10:46
  • \$\begingroup\$ @pdb5627 You are correct. I could have added a bit to my "simplistically". Should more properly be put ~~= "By increasing or decreasing power input operators can control the amount of energy supplied ...". \$\endgroup\$
    – Russell McMahon
    Sep 19, 2022 at 11:38
