I'm working on a transformer active battery balancing circuit and have it working except, due to the diode voltage drop on the secondary, I need an alternative.
Since the battery cell voltage is 4 V, a 1 V drop is 25% efficiency loss and obviously will have huge imbalance issues. I thought about adding another winding on the transformer to increase the voltage but would instead like to add a active diode.
I tried the following circuit design but it's not working. The IGBT is not turning on fully and only allowing 1.5 V through. I am using a RJP30E2 which has a saturation voltage of 1.7 V. The transformer is running at 120 kHz.
I have very little experience and understanding of electronics and started this project a few weeks ago.
    \$\begingroup\$ Why can't you use MOSFETs a la H-bridge? \$\endgroup\$
    Commented Sep 15, 2022 at 18:23
    \$\begingroup\$ Please show the circuit that doesn't work. The link shows a circuit with a transformer and diodes \$\endgroup\$ Commented Sep 15, 2022 at 18:33
  • \$\begingroup\$ All the mosfets I looked into have a too high of a gate voltage \$\endgroup\$ Commented Sep 15, 2022 at 18:48
  • \$\begingroup\$ heres the correct link: falstad.com/circuit/… \$\endgroup\$ Commented Sep 15, 2022 at 18:50
    \$\begingroup\$ ive redid the schematic with circuit labs and embeded it into the question \$\endgroup\$ Commented Sep 15, 2022 at 19:14
Although 15 A is a lot of current for a logic-level MOSFET, all hope is not lost.
Take, for instance, a DMN2011. Let's look at the datasheet.
First things first, lets check out the Electrical Characteristics on Page 2 and see what the "On Characteristics" looks like. We want to scrutinize the "Static Drain-to-Source On-Resistance":
This is looking promising! Let's investigate further.
On page 3, figures 1 and 3:
Figure 1 shows us that current is pretty linear with voltage at 15 A with Vgs of 1.8 V and higher.
Figure 3 shows us that the drain to source resistance at Vgs of 2.5 V and 15 A is only about 0.009 Ω. Nine Milliohm!
Using Ohm's law, 15 A over 9 mΩ drops only 0.135 V.
Depending on your other requirements, something like this could work.
    \$\begingroup\$ Thank you so much! I have no clue how you found this but so far this seems perfect. First time ordering on digikey, hopefully it arrives soon and this fixes the problem. Was worried that I was missing something other than the Vgs being not low enough. \$\endgroup\$ Commented Sep 15, 2022 at 20:57
    \$\begingroup\$ @robertkaras I don't know what the rest of your circuit looks like, so there is still room to mess it up! :-) If it doesn't work, come on back and we'll get it sorted out. \$\endgroup\$ Commented Sep 15, 2022 at 21:00
