What is the name of this connector ?
I need to replace it but I don't know what to search for.
Edit : I added 2 photos. If it can help, the card is an SW200D1 from Advisen.
    \$\begingroup\$ What are the dimensions of the plug and what is the pitch (center-to-center spacing of the contacts)? Also, can you pull the plug and show us the mating face? \$\endgroup\$
    – vir
    Sep 15, 2022 at 21:07
    \$\begingroup\$ It could be a "molex", but that's like saying "Ford." \$\endgroup\$
    – rdtsc
    Sep 15, 2022 at 21:34
    \$\begingroup\$ Also it matters if the pitch is for example 5.00mm or 5.08mm (0.2'') which isn't easy to measure. \$\endgroup\$
    – Lundin
    Sep 16, 2022 at 8:21
    \$\begingroup\$ also what shape and size are the pins. \$\endgroup\$ Sep 16, 2022 at 23:52
    \$\begingroup\$ Also how good are you at crimping terminals when you don't have the correct crimp tool? I guess maybe you'll be able to find a pre-loaded connector and splice the wires instead. \$\endgroup\$ Sep 17, 2022 at 0:00
That is a single wall, wire-to-board connector, 3.96 mm pitch (my site). Manufacturers include:
  • MANUF. - SERIES
  • Adam tech - LHB LHC LHD + MTB (crimp)
  • Molex - KK 171813 KK 171814 KK 41671 KK 41672 KK41681 KK41682 KK41791 KK41792 KK42491 KK42492 KK42891 KK42892 KK5273 KK5274 KK5277 KK8619 MV-396 + KK 2139 KK 3069 kk 5239 KK 6442 KK 41695 SPOX 43061 SPOX 5195 SPOX 5196
  • Molex - KK 3190 + KK 2139 KK 3069 kk 5239 KK 6442 KK 41695 SPOX 43061 SPOX 5195 SPOX 5196
  • OnShore - 8673-xx-S + 8639-xx
  • TE - MTA-156 + SL-156 (1w crimp)
  • Wurth - WR-WTB 645
You can buy the housing here but you also may need to buy crimp contacts for it, which depend on the wire size.
  • \$\begingroup\$ Are Molex's KK and SPOX series cross-compatible? \$\endgroup\$
    – Hearth
    Sep 17, 2022 at 15:18
  • \$\begingroup\$ It's complicated. They are both trademarks that are used in multiple connector families. There is no single "KK" family and there is no single "Spox" family. So, not answerable. \$\endgroup\$ Sep 18, 2022 at 18:06
  • \$\begingroup\$ I ask because you list a bunch of KK part numbers and a bunch of SPOX part numbers. Are all of those connectors listed compatible? \$\endgroup\$
    – Hearth
    Sep 18, 2022 at 18:08
  • \$\begingroup\$ Not exactly. They are all slightly different one way or another. For example, some have friction lock and some don't, some have two wings for polarization, some don't, some are natural Nylon, some are while polyester. I gave the person asking a list of choices. \$\endgroup\$ Sep 18, 2022 at 19:45
  • \$\begingroup\$ You should perhaps make that a bit clearer, then. Say something along the lines of "It's probably one of these", rather than "manufacturers include", which suggests this is a specific very standard part that many manufacturers make compatible parts for. \$\endgroup\$
    – Hearth
    Sep 18, 2022 at 20:01
