Is there a better way to cycle through 3 outputs in a loop on clock input? I'm currently using a CD4017 with the 4th counter tied back to reset, and this does work well enough.
The fact that it is a single IC is a plus for me here, it seems like I'm not doing something right though with only using a third of the decade counter. I haven't been able to find anything like a half decade counter or the like when searching through digikey components.
Appreciate any thoughts on the matter.
Counter circuit with CD4017
You're not doing anything "wrong" using the 4017 connected like that. You might be able to use some flip-flops connected together or a shift register to get the same functionality, but there would be no savings in pin count or complexity. You could use a 6- or 8-pin microcontroller with a few lines of code on it, which would also enable you to include some additional functionality and maybe eliminate the need for some other parts of your circuit.
  • \$\begingroup\$ Linked flip flops had been an earlier consideration that I had dropped for exactly that reason of complexity and pin count. I hadn't considered a smaller microcontroller though. That's an interesting idea, and I think I could save space even with having the programming pads. Much appreciated. \$\endgroup\$ Sep 16, 2022 at 17:59
