I purchased a simple ZVS driver off Amazon to use with a Cockcroft-Walton multiplier I plan on building, but wanted to test the circuit in Multisim first before adding it. The ZVS Driver works well so far, successfully completing an arc across a distance of 5mm between leads. My fluke hv probe is measuring the output at around 11kV. In Multisim, I usually test the output of my power supply circuits with a connector, but after measuring extremely low voltages at output I thought I must be doing something wrong. After looking at other ZVS driver circuits in Multisim I discovered that even though output should be AC (at least with irl multimeter readings...) this circuit seems to only measure the voltage correctly with a DC current source attached to both output terminals. Any thoughts on why this is? Any help is greatly appreciated!
With connector
With DC current source
You must connect the output coil to ground to make the simulator work correctly. There is no ground reference to the HV secondary.
  • \$\begingroup\$ I added the schematic from the manufacturer to the original comment for reference. \$\endgroup\$ Sep 18, 2022 at 6:39
