This is my Arduino code:
https://create.arduino.cc/projecthub/kksjunior/48-x-8-scrolling-led-matrix-using-arduino-9a53b8
char msg[] ="EF";
int scrollspeed=25;//Set the scroll speed ( lower=faster)
int x;
int y;
//Columns
int clockPin1 = 2; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin1 = 3; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin1 = 4;  //Arduino pin connected to Data Pin 14 of 74HC595
//Rows ---> نهایت دو یا سه تا
int clockPin2 = 5; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin2 = 6; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin2 = 7;  //Arduino pin connected to Data Pin 14 of 74HC595
//BITMAP
//Bits in this array represents one LED of the matrix
// 8 is # of rows, 6 is # of LED matrices
byte bitmap[8][7];
int numZones = sizeof(bitmap) / 8; // One Zone refers to one 8 x 8 Matrix ( Group of 8 columns)
int maxZoneIndex = numZones-1;
int numCols = numZones * 8;
//FONT DEFENITION
byte sanyeh [1][8]= {{0,31,255,31,0}};
//byte daghigheh [5]= {0x00,0xE9,0x89,0xE9,0x29,0xEF,0x00,0x00};
//byte saat [5]=  {0x00,0xE9,0x89,0xE9,0x29,0xEF,0x00,0x00};
byte alphabets[][8] = {
 {0,0,0,0,0},//@ as SPACE
 {8,28,54,99,65},//<<
 {0,31,255,31,0},//A
 {127, 73, 73, 73, 54},//B
 {62, 65, 65, 65, 34},//C
 {127, 65, 65, 34, 28},//D
 {127, 73, 73, 65, 65},//E
 {127, 72, 72, 72, 64},//F
 {62, 65, 65, 69, 38},//G
 {127, 8, 8, 8, 127},//H
 {0, 65, 127, 65, 0},//I
 {2, 1, 1, 1, 126},//J
 {127, 8, 20, 34, 65},//K
 {127, 1, 1, 1, 1},//L
 {127, 32, 16, 32, 127},//M
 {127, 32, 16, 8, 127},//N
 {62, 65, 65, 65, 62},//O
 {127, 72, 72, 72, 48},//P
 {62, 65, 69, 66, 61},//Q
 {127, 72, 76, 74, 49},//R
 {50, 73, 73, 73, 38},//S
 {64, 64, 127, 64, 64},//T
 {126, 1, 1, 1, 126},//U
 {124, 2, 1, 2, 124},//V
 {126, 1, 6, 1, 126},//W
 {99, 20, 8, 20, 99},//X
 {96, 16, 15, 16, 96},//Y
 {67, 69, 73, 81, 97},//Z
void setup() {
 pinMode(9, OUTPUT);
 pinMode(latchPin1, OUTPUT);
 pinMode(clockPin1, OUTPUT);
 pinMode(dataPin1, OUTPUT);
 pinMode(latchPin2, OUTPUT);
 pinMode(clockPin2, OUTPUT);
 pinMode(dataPin2, OUTPUT);
 //Clear bitmap
 for (int row = 0; row < 8; row++) {
   for (int zone = 0; zone <= maxZoneIndex; zone++) {
     bitmap[row][zone] = 0;
//FUNCTIONS
// Displays bitmap array in the matrix
void RefreshDisplay()
   int rowbit = 1 << row;
   digitalWrite(latchPin2, LOW);//Hold latchPin LOW for transmitting data
   shiftOut(dataPin2, clockPin2, MSBFIRST, rowbit);   //Transmit data
     delayMicroseconds(200);
   //Start sending column bytes
   digitalWrite(latchPin1, LOW);//Hold latchPin LOW for transmitting data
   //Shift out to each matrix
   for (int zone = maxZoneIndex; zone >= 0; zone--)
     shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
   //flip both latches at once to eliminate flicker
   digitalWrite(latchPin1, HIGH);//Return the latch pin 1 high to signal chip
   digitalWrite(latchPin2, HIGH);//Return the latch pin 2 high to signal chip
   //Wait
   //delayMicroseconds(200);
   //delay(10);
   //delayMicroseconds(800);
   //delay(10);
//// Converts row and colum to bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
 int zone = col / 8;
 int colBitIndex = x % 8;
 byte colBit = 1 << colBitIndex;
 if (isOn)
   bitmap[row][zone] =  bitmap[y][zone] | colBit;
 else
   bitmap[row][zone] =  bitmap[y][zone] & (~colBit);
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void XProcess()
 for (int charIndex=0; charIndex < (sizeof(msg)-1); charIndex++)
   int alphabetIndex = msg[charIndex] - '@';
   if (alphabetIndex < 0) alphabetIndex=0;
   //Draw one character of the message
   // Each character is 5 columns wide, loop two more times to create 2 pixel space betwen characters
   for (int col = 0; col < 7; col++)
       // Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
       bool isOn = 0;
       if (col<5) isOn = bitRead( alphabets[alphabetIndex][col], 7-row ) == 1;
       Plot( numCols-1, row, isOn); //Draw on the rightmost column, the shift loop below will scroll it leftward.
     for (int refreshCount=0; refreshCount < scrollspeed; refreshCount++)
       RefreshDisplay();
     //Shift the bitmap one column to left
     for (int row=0; row<8; row++)
       for (int zone=0; zone < numZones; zone++)
         //This right shift would show as a left scroll on display because leftmost column is represented by least significant bit of the byte.
         bitmap[row][zone] = bitmap[row][zone] >> 1;
         // Shift over lowest bit from the next zone as highest bit of this zone.
         if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone+1],0));
void loop() {
 //digitalWrite(9,HIGH);
 //RefreshDisplay();
 XProcess();
 //delay(50);
 //digitalWrite(9,LOW);
When I simulate it in Proteus, it does not display and scroll correctly. Can you help me?
This is my Proteus circuit:
New contributor
Reza is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ "... it does not display and scroll correctly." What does it do? \$\endgroup\$
    – Transistor
    2 days ago
  • \$\begingroup\$ i say display and scroll is not clear \$\endgroup\$
    – Reza
    2 days ago
    \$\begingroup\$ You need to give more detail. It scrolls but the letters are not correct? The letters are OK but it doesn't scroll? It blinks? It scrolls too fast? Can you disable the scroll and display a few characters? Can you display one character and then scroll it? \$\endgroup\$
    – Transistor
    2 days ago
  • \$\begingroup\$ Whats about pin 10 of U2 U3 and U4? This is the active low reset input of the shift register. What is connected to these inputs? \$\endgroup\$
    – Uwe
    2 days ago
  • \$\begingroup\$ yes.it desplay characters ,but characters scroll fast blink. \$\endgroup\$
    – Reza
    2 days ago
Column outputs Rxx ...
For displaying, OE\ should be low.
For shifting data, OE\ should be high.
NB: the two clocks are tied together.
Therefore, outputs used are "DATA", "CLK", "OE" for "Arduino"
Link file Made with microcap v12
NB: U22 does not tri-state outputs, little model problem.
Reza is a new contributor. Be nice, and check out our Code of Conduct.
