My idea is to monitor power consumption and automatically turn off the outlet based on time and power consumption (e.g. at night, but only if nothing has been running for a while).
Most important is monitoring the power consumption, in particular I want to get the data to a Raspberry Pi.
My thoughts what it should do:
  • Can measure power consumption and ideally turn output on/off
  • Must have an open interface and not send any data to a server
  • Maybe Zigbee/Z-wave instead of WiFi for power efficiency?
Is there such a wireless outlet, what should I look for? Does my idea even make sense from a technical perspective? I'm a computer scientist, so my electronics knowledge is limited.
  • \$\begingroup\$ If you power down an outlet with power consumption below a threshold, how do switch on a connected device when there is no power at the outlet? \$\endgroup\$
    – Uwe
    Sep 23 at 18:50
  • \$\begingroup\$ The threshold is only one factor, I would enable it automatically at 'work times', or manually switch it on; it should be controllable by the pi / me \$\endgroup\$ Sep 23 at 23:54
