Trying to repair an electric mattress pad and need to ID this connector connector
    \$\begingroup\$ A blurry white one? :) Might be an MLX power type with 3 wires, though. \$\endgroup\$
    – jonk
    Commented Sep 25, 2022 at 3:31
  • \$\begingroup\$ Thanks, sounds about right. Sorry for the blurry pic, cropped from a larger photo. \$\endgroup\$
    – zencraft
    Commented Sep 25, 2022 at 3:56
  • \$\begingroup\$ What's the pin pitch? It might be Molex, might be TE/Amp. \$\endgroup\$
    – Hearth
    Commented Sep 25, 2022 at 4:10
  • \$\begingroup\$ Actually what I really need to know is the kind of pin used inside (so I can replace it), I figure there must be a lot fewer varieties of pins than connectors \$\endgroup\$
    – zencraft
    Commented Sep 25, 2022 at 8:47
TE, Universal MATE-N-LOK II
Found using my connector identification utility
TE 350767-1
TE 350767-1
{Picture from Digikey's website}
You can buy it from Digikey. The contacts are listed at the bottom of that page.
  • \$\begingroup\$ That's awesome, thank you! \$\endgroup\$
    – zencraft
    Commented Sep 27, 2022 at 0:33
  • \$\begingroup\$ Are all Mate-N-Lok connector pins interchangeable (same pin length and diameter, different only in wire gauge/material/finish/packaging)? The fools used 28AWG wire in a 14-20AWG pin, so I thought I'd get the right gauge pin. \$\endgroup\$
    – zencraft
    Commented Sep 27, 2022 at 23:47
  • \$\begingroup\$ No, They are not. Pins come in 3 mating diameters, and pitches vary allover the place. \$\endgroup\$ Commented Sep 29, 2022 at 17:12
  • \$\begingroup\$ I thought pitch was the center-to-center distance between pins, so that would be a spec of the connector housing, not the pin, no? Or is this a different pitch? Is there an easy overview guide for the world of connectors? \$\endgroup\$
    – zencraft
    Commented Sep 30, 2022 at 4:45
  • \$\begingroup\$ "I thought pitch was the center-to-center distance between pin". Yes, it is. "so that would be a spec of the connector housing, not the pin, no". Correct. "Or is this a different pitch?" In this family you can have different pitches for different number of contacts, even if they all use the same pin size. That's uncommon. Normally, a family of connectors all have the same pitch. \$\endgroup\$ Commented Sep 30, 2022 at 17:40
