I am trying to find a formula for voltage and delay time, but I don't know if there is a relation between delay time and voltage. For example if I need 100V, I should use X ms delay time.
I found this formula in a physics forum. User Jony130 gives the formula.
I will give the Vload to MCU and expect it to calculate the delay time with a formula. I tried to create a formula between degrees as radian and voltage according to Jony130's formula. I couldn't do it.
- Is there linear relation between voltage and delay time?
- If yes, how can I create the formula?
Update:
clc;
clear all;
piValue = 1/(2*pi);
Vm = 220; %Vmax = 220V
for i=1:1:180
a = (i*pi)/180;
Vload(i) = real(Vm*sqrt(piValue*((pi-a)+(sin(2*a)/2)))*1.41);
end
I made calculation using MATLAB. These are the results that I got. Shouldn't I get 220V when the degree is 0 and also 110V when the degree is 90 ? It's 110V when it is 90 degree. However, it's not 220V when degree is 0.
155.563404112011 155.562789995711 155.561123774353 155.557880953464 155.552538876660 155.544577300795 155.533478951120 155.518730056150 155.499820862054 155.476246126473 155.447505591725 155.413104437476 155.372553712985 155.325370749122 155.271079550396 155.209211167293 155.139304049274 155.060904378791 154.973566386766 154.876852649953 154.770334370667 154.653591639364 154.526213680574 154.387799082713 154.237956012293 154.076302413056 153.902466190581 153.716085382880 153.516808317522 153.304293755813 153.078211024532 152.838240135765 152.584071895297 152.315408000090 152.031961125294 151.733455001265 151.419624481049 151.090215598751 150.744985619221 150.383703079457 150.006147822127 149.612111021565 149.201395202625 148.773814252722 148.329193427403 147.867369349747 147.388190003921 146.891514723153 146.377214172419 145.845170326089 145.295276440790 144.727437023720 144.141567796631 143.537595655705 142.915458627518 142.275105821279 141.616497377539 140.939604413529 140.244408965302 139.530903926819 138.799092986146 138.048990558880 137.280621718955 136.494022126944 135.689237955972 134.866325815370 134.025352672167 133.166395770519 132.289542549193 131.394890557179 130.482547367539 129.552630489576 128.605267279393 127.640594848957 126.658759973713 125.659918998847 124.644237744270 123.611891408394 122.563064470775 121.497950593698 120.416752522774 119.319681986622 118.206959595706 117.078814740398 115.935485488350 114.777218481229 113.604268830912 112.416900015201 111.215383773135 110 108.771036642087 107.528789591311 106.273562579758 105.005667074269 103.725422171137 102.433154491031 101.129198074241 99.8138942763547 98.4875916644782 97.1506459141236 95.8034197068806 94.4462826290131 93.0796110711142 91.7037881289713 90.3192035057960 88.9262534159873 87.5253404906026 86.1168736847286 84.7012681869512 83.2789453311404 81.8503325107803 80.4158630960921 78.9759763542133 77.5311173727192 76.0817369867938 74.6282917103783 73.1712436716575 71.7110605532673 70.2482155376443 68.7831872579690 67.3164597551979 65.8485224417214 64.3798700722323 62.9110027224475 61.4424257763812 59.9746499229401 58.5081911626850 57.0435708256872 55.5813156015068 54.1219575824270 52.6660343211985 51.2140889046909 49.7666700450011 48.3243321897511 46.8876356535082 45.4571467724991 44.0334380850534 42.6170885405246 41.2086837397909 39.8088162108545 38.4180857235362 37.0370996478256 35.6664733611017 34.3068307102131 32.9588045353168 31.6230372634575 30.3001815811531 28.9909011967950 27.6958717055220 26.4157815714677 25.1513332450013 23.9032444359183 22.6722495676338 21.4591014425216 20.2645731548901 19.0894602960822 17.9345835063348 16.8007914410299 15.6889642357922 14.6000175768676 13.5349075123076 12.4946361784364 11.4802586689942 10.4928913473174 9.53372200427160 8.60402241092457 7.70516402845776 6.83863795693910 6.00608069463758 5.20930805580732 4.45036086952568 3.73156826581312 3.05563829033722 2.42579313150406 1.84598185936478 1.32123929241027 0.858353109415476 0.467299422404012 0.165230394247177 0
