My question is very similar to Converting Open-Drain to Active-High, however instead of an active high, I want an active low.
I am trying to interface TI BQ51050B (QI receiver + LiPo Charger) and TI TPS63051 (3.3V Buck-Boost) with a 3.7V LiPo. The BQ CHG pin is an open drain output pin, and the TPS EN pin is an input (1: enabled, 0: disabled).
My thinking is that when the battery is charging(CHG-> GND), I don't want it to be attached to any load(EN->LOW), and when the battery isn't charging(CHG->Hi-Z), It should be attached to the load(EN->HIGH).
Input(CHG) Output(EN)
GND LOW
Hi-Z HIGH
I was thinking of just using the circuit in the previously mentioned post with a NOT gate attached to the output which would give:
Using the CircuitLab simulation, I get the desired results on EN (3.7V when CHG is Hi-Z, 11mV when CHG is shorted to GND).
However, I was wondering if there is a better way to do this. If this is the best way, would the NXP BCW29 work for Q2 and the NXP PMBT3904 work for Q3?
An open drain just means that a MOSFET internally connects the pin to ground inside the IC:
The output being Hi-Z just means that the MOSFET is switched off. When the MOSFET is switched on, the output is pulled to ground.
If you want to turn the Hi-Z state to a logical HIGH, all you need is a pullup resistor:
When the output is in a Hi-Z state, the MOSFET is off and the resistor pulls the output voltage up to 3.3V. When the output is in an active-low state, the MOSFET is on and pulls the output voltage down to 0V.
  • \$\begingroup\$ Thank you. Can't believe I didn't think of this. \$\endgroup\$
    – jb0
    Sep 29, 2022 at 0:30
  • \$\begingroup\$ No worries. Really easy to miss the simple solutions sometimes :) \$\endgroup\$
    – Polynomial
    Sep 29, 2022 at 0:43
