I thought of creating a circuit for a light barrier. I got the required components: an IR LED diode, an IR phototransistor, an op-amp, a potentiometer, a blue LED, and resistors. After much testing and re-building I came up with this circuit which works well enough:
Until I removed the multimeter I used for testing. After that, the phototransistor stopped turning on the LED when the beam of light from the IR LED was interrupted.
I thought the multimeter took some current from the circuit, and moved the threshold for the LED to turn on. I rotated the potentiometer to both sides (moved a few hundred millivolts and interrupted the light barrier, and then moved again) and the LED stayed either on or off, not changing its state when the beam was interrupted.
I can't test this unknown state, because when I plug in the multimeter it works again. I can't have a multimeter always on next to the circuit to make it work. There is probably some beginner mistake I simply overlooked.
  • \$\begingroup\$ The multimeter is the bottom leg of the voltage divider at the minus input of the opamp. The phototransistor is the top leg. A typical modern multimeter has an input impedance of 10M. You probably don't want to use a resistor that large, try a 100k or 1M in place of the multimeter. \$\endgroup\$
    – Mattman944
    Commented Sep 29, 2022 at 15:42
There's no sort of voltage divider on the -ve input to the OA1. If the prototransistor leaks any current at all when off, even a few microamps, then the -ve input will be pulled high to 5V all the time.
A typical digital multimeter has a resistance of 10M ohms. By connecting it, you're creating the missing voltage divider. So when the phototransistor is off, the -ve input is pulled to ground.
  • \$\begingroup\$ I added a 40kΩ resistor on inverting and non-inverting inputs of the op-amp and it works now perfectly. Thank you very much for the answer \$\endgroup\$
    – EndrManCZ
    Commented Sep 29, 2022 at 16:07
