I'm reading the book http://www.cs.indiana.edu/~geobrown/book.pdf and I have a question regarding the Exercise 3.1.2 on page 50.
It ask to set a watchpoint on i. I set a watchpoint but it never break the code. I tried breakpoint a function as the book said and it worked.
It is related to tool stlink?
  • \$\begingroup\$ It may be that this does not work; watchpoints are tricky to support, extremely so if the variable is not declared volatile. There are almost always alternative techniques you can employ with a little creative thinking. \$\endgroup\$ – Chris Stratton Mar 28 '13 at 16:48
If the source code was compiled so that it could be easily debugged (typically the switch -g) then you can just call in your GDB client:
watch x
Where x is the variable in your code you want to watch. Although its highly likely that it might not be supported by your GDB client for you microcontroller.
  • \$\begingroup\$ Thanks! I removed the optimization flag -O1 and now the watch works :) \$\endgroup\$ – metRo_ Mar 31 '13 at 18:33
