I got this LED strip that I'm trying to control with my arduino. I searched for similar strips online but couldn't find any. I only has leads for DIN (blue), GND (black, splits in 2), and +5V (red). I couldn't find the data sheet and the part number didn't generate any results when I Google searched it. All i really need to know is the name of this type of LED strip so I can continue to research how to control it, but if there are any tutorials out there that use this type of strip, a link would be much appreciated.
led strip end led strip connectors led strip
  • \$\begingroup\$ Its hard to see whats actually in there from those photos. All I see is what looks like an RGB led(?) and a limitting resistor(??). Isn't there a control chip in each segment? Try searching on the chip number if so. Pololu sells led strips and HobbyKing has a few different types (without much additional info though, Im afraid). \$\endgroup\$
    – Octopus
    Mar 28, 2013 at 22:28
  • \$\begingroup\$ @Octopus you will get the rep one day, just right a few serious answers and you can make comments in no time. :) \$\endgroup\$
    – Kortuk
    Mar 29, 2013 at 3:19
It looks similar to this LED strip: http://www.adafruit.com/products/1138
According to the code linked from that page, it's controlled by a weird protocol used by the Worldsemi WS2811 LED driver chips on the strip: 24 bits for each RGB LED, 800 or 400 kHz data rate, 50 microsecond pause to latch the data. There is a pulse for each bit, 0 bits are a short pulse, and 1 bits are a long pulse.
  • \$\begingroup\$ You are my hero. \$\endgroup\$
    – tyjkenn
    Mar 28, 2013 at 23:23
    \$\begingroup\$ Without any codes or information, it's hard to tell if this is correct. It does look similar, probably a 30 led per meter version of the Adafruit one, but WS2811 or similar protocol is hardly the only led strip that uses only three pins. \$\endgroup\$
    – Passerby
    Mar 28, 2013 at 23:30
  • \$\begingroup\$ This is the one. I got it working. \$\endgroup\$
    – tyjkenn
    Mar 29, 2013 at 2:55
