Schematic
I was going through a book, and there is this exercise that I need to solve with Verilog. I wrote this code, but it's giving me this error:
main.v:20: syntax error
main.v:20: error: Invalid module instantiation
Any help would be hugely appreciated. Code is:
module Exercise(A,B,C);
  input A,B;
  output C;
  wire w1,w2;
  not not1(w1,B);
  or or1(w2,B,w1);
  or or2(C,A,w2);
endmodule
module main;
  reg A,B;
  wire C;
  Exercise exer1(C,A,B);
  initial
      begin
      A = 0;
      B = 1;
      #5;
      $display("Result = ",C);
    end
endmodule
The problem is with the connections to the module instance. You connected a reg to the module output: B in the main module is connected to C in the Exercise module.
You are using connection by order, but you should use connection by name.
Change:
to:
  Exercise exer1 (.C(C), .A(A), .B(B));
Here is the new main module.
module main;
  reg A,B;
  wire C;
  initial
      begin
      A = 0;
      B = 1;
      #5;
    end
endmodule
Your simulator error message is not very specific. You can get more helpful error messages with other simulators which are available on EDA Playground. This link has a complete, runnable code example which proves that the code no longer has a syntax error.
See also: How to instantiate a module
