Are ESD wrist straps, gloves and table mats safe to use while handling a live PCB or a turned on Raspberry Pi, for example?
What I intend is to protect the components against static discharges.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityAre ESD wrist straps, gloves and table mats safe to use while handling a live PCB or a turned on Raspberry Pi, for example?
Yes it is safe and the preferred approach.
ESD wristbands, table mats, etc. are usually connected to protective earth through a 1 MΩ resistor.
Yes: boards that are low-voltage safe to handle without ESD protection are safe to handle with it.
The ESD protection mats, gloves etc. are made of higher-resistance material. So they won't conduct enough current from the low voltage to dissipate damaging power in the circuit.
However, the operation of circuits using very high resistances, like 100's kohms, can be affected by putting a gloved finger on them. That won't result in damage, just a change in performance.
An extra effect is added by the connection of the ESD protection to ground through the 1 Mohm or so resistance used by ESD earthing equipment.
It's therefore good practice to not operate boards that are lying flat on an ESD mat, for example. It doesn't mean they will start behaving differently. Instead, it rules out the possibility that they are ever behaving differently. Hence good practice, not necessity.
