Background
I'm writing a .s2p/Touchstone library for Perl and I'm trying to get the Q value of a component given an S-parameter matrix.
The Goal
In this case I'm trying to get Q for a 10nF muRata capacitor. I'm checking correctness against the Q graph in their SimSurfing app and so far the result isn't lining up to what they provide.
What I've tried
Given that \$ Q_C = \frac{X_C}{ESR} \$, I have already validated that \$X_C\$ is correct (by comparing to muRata's graphs) but I've not found a way to calculate ESR to find \$Q_C\$. Somewhere I read that \$ESR=\frac{-1}{Re(Y_{12})}\$ but the values aren't coming out right, so maybe that is true only under certain conditions? (I know that \$Y_{12}\$ is correct because the capacitance value using \$Y_{12}\$ is close to 10nF.)
This reference provides quite a few from S-parameter conversions, but not ESR. I've read articles about how it relates to tan(dissipation) and how to measure ESR...but nothing on how to get ESR from S-parameters.
The questions
I can convert S-parameters to Y, Z, ABCD, T, or whatever...so if those are better for this purpose then I'm fine with that too.
  1. So this question is fundamentally:
    • How do you calculate Q from S-parameters?
  2. However as an xyproblem, an answer to this question would also suffice because it provides #1:
    • How do you calculate ESR from S-parameters?
It turns out my math for ESR was wrong.
  1. Above I have this which is incorrect, at least for Y-parameters that have complex values:
    • \$ESR=\frac{-1}{Re(Y_{12})}\$
  2. The correct form to calculate ESR is:
    • \$ESR=Re(\frac{-1}{Y_{12}})\$
Subtle difference! Now my numbers match muRata's.
  • \$\begingroup\$ Shows the 'Teddy Bear Effect' is alive and well! \$\endgroup\$
    – Neil_UK
    Commented Oct 6, 2022 at 5:21
