I am using CCS 5.x on Windows 7. The TI board is LM4f232. The following code performs A to D conversion of the on-board accelerometer. I am trying to use printf to see my variable values, but it is failing.
    #include "utils/ustdlib.h"
    #include "inc/hw_types.h"
    #include "driverlib/adc.h"
    #include "inc/hw_memmap.h"
    #include "driverlib/sysctl.h"
    #include "driverlib/pin_map.h"
    #include "driverlib/gpio.h"
    #include "stdio.h"
    #ifdef DEBUG
    void
    __error__(char *pcFilename, unsigned long ulLine)
    #endif
    int main(void)
    unsigned long ulADC0_Value[3]; //holds ADC output values
    //Configure the system clock to 50MHz
    SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
    //GPIO Configuration
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
    GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_6);
    //ADC Configuration starts here
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
    ADCSequenceConfigure(ADC0_BASE, 0, ADC_TRIGGER_PROCESSOR, 0);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 0, ADC_CTL_CH8);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 1, ADC_CTL_CH9);
    ADCSequenceStepConfigure(ADC0_BASE, 0, 2, ADC_CTL_CH21 | ADC_CTL_IE | ADC_CTL_END);
    ADCSequenceEnable(ADC0_BASE, 0);
    //ADC measurement is made here
    while(1)
        //trigger ADC measurement
       ADCProcessorTrigger(ADC0_BASE, 0);
       //wait for the conversion to complete
       while(!ADCIntStatus(ADC0_BASE, 0, false))
            //transfer data from FIFO to local variable
       ADCSequenceDataGet(ADC0_BASE, 0, ulADC0_Value);
       // this line creates problem
        printf("values %l", ulADC0_Value[0]);
            //Delay between samples
        SysCtlDelay(SysCtlClockGet() / 12);
The following is the content of my startup_ccs.c file (some part is clipped)
// startup_ccs.c - Startup code for use with TI's Code Composer Studio.
// Copyright (c) 2011-2012 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
// Texas Instruments (TI) is supplying this software for use solely and
// exclusively on TI's microcontroller products. The software is owned by
// TI and/or its suppliers, and is protected under applicable copyright
// laws. You may not combine this software with "viral" open-source
// software in order to form a larger program.
// THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
// NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
// NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
// CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
// DAMAGES, FOR ANY REASON WHATSOEVER.
// This is part of revision 9107 of the EK-LM4F232 Firmware Package.
// Forward declaration of the default fault handlers.
void ResetISR(void);
static void NmiSR(void);
static void FaultISR(void);
static void IntDefaultHandler(void);
// External declaration for the reset handler that is to be called when the
// processor is started
extern void _c_int00(void);
// Linker variable that marks the top of the stack.
extern unsigned long __STACK_TOP;
// The vector table.  Note that the proper constructs must be placed on this to
// ensure that it ends up at physical address 0x0000.0000 or at the start of
// the program if located at a start address other than 0.
#pragma DATA_SECTION(g_pfnVectors, ".intvecs")
void (* const g_pfnVectors[])(void) =
    (void (*)(void))((unsigned long)&__STACK_TOP),
                                            // The initial stack pointer
    ResetISR,                               // The reset handler
    NmiSR,                                  // The NMI handler
     IntDefaultHandler,                      // FPU
    IntDefaultHandler,                      // PECI 0
    IntDefaultHandler,                      // LPC 0
    IntDefaultHandler,                      // GPIO Port R
    IntDefaultHandler,                      // GPIO Port S
    IntDefaultHandler,                      // PWM 1 Generator 0
    IntDefaultHandler,                      // PWM 1 Generator 1
    IntDefaultHandler,                      // PWM 1 Generator 2
    IntDefaultHandler,                      // PWM 1 Generator 3
    IntDefaultHandler                       // PWM 1 Fault
// This is the code that gets called when the processor first starts execution
// following a reset event.  Only the absolutely necessary set is performed,
// after which the application supplied entry() routine is called.  Any fancy
// actions (such as making decisions based on the reset cause register, and
// resetting the bits in that register) are left solely in the hands of the
// application.
void
ResetISR(void)
    // Jump to the CCS C initialization routine.  This will enable the
    // floating-point unit as well, so that does not need to be done here.
    __asm("    .global _c_int00\n"
          "    b.w     _c_int00");
// This is the code that gets called when the processor receives a NMI.  This
// simply enters an infinite loop, preserving the system state for examination
// by a debugger.
static void
NmiSR(void)
    // Enter an infinite loop.
    while(1)
// This is the code that gets called when the processor receives a fault
// interrupt.  This simply enters an infinite loop, preserving the system state
// for examination by a debugger.
static void
FaultISR(void)
    while(1)
// This is the code that gets called when the processor receives an unexpected
static void
    // Go into an infinite loop.
    while(1)
Whenever I put printf:
 printf("values %lu", ulADC0_Value[0]);
and even
shown in my first code after ADCSequenceDataGet(), the program stops, and the control goes to the following section in startup_css.c:
static void
FaultISR(void)
    while(1)
I followed the instructions given here on printf support and increased the heap size to 500 bytes, but still I am not able to print the variable values on console. What is wrong with my code?
  • \$\begingroup\$ Your heap is 500 bytes but what about your stack? How big is that? Try using #include <stdio.h> instead of #include "stdio.h". Also try moving the call to SysCtlDelay above your printf. \$\endgroup\$ Commented Mar 29, 2013 at 14:01
  • \$\begingroup\$ @embedded.kyle thanks for your suggestions and edits. Stack is by default 256 bytes, so I increased the stack to 512. Also moved SysCtlDelay above printf, but still same issue... \$\endgroup\$
    – gpuguy
    Commented Mar 29, 2013 at 14:18
  • \$\begingroup\$ And the #include? The behavior is implementation defined but you may be pulling a different copy of stdio.h than the one you want. \$\endgroup\$ Commented Mar 29, 2013 at 14:24
  • \$\begingroup\$ did that also, again the same problem. Under Expressions I get: ulADC0_Value unknown Error: identifier not found: ulADC0_Value. \$\endgroup\$
    – gpuguy
    Commented Mar 29, 2013 at 14:32
  • \$\begingroup\$ What sort of debugging can you do? Have you been able to step inside the printf call and see what it attempts to do and where exactly the fault occurs? \$\endgroup\$
    – AngryEE
    Commented Mar 29, 2013 at 15:30
I had the same problem. It took me 2 hours to find the solution.
--printf_support=minimal in the compile options is the root cause of some printf formats not working.
Change it to --printf_support=full and it will fix the problem.
It's explained on page 29 of MSP430 Optimizing C/C++ Compiler v21.6.0.LTS
