I want to convert USART signals to RS485 with the circuit below: enter image description here
I log the data on the USART6_TX and 485A/485B at the same time, but the data on the output pins of the MAX485 is wrong and it's not similar to data on USART6_TX. the DE/RE pin of the IC is connected to the GPIO pin of the microcontroller. the microcontroller pulls up the pin while transferring data.
I transmit the data every 3seconds. the picture below is captured from USART6_TX pin and this is the data I expect to see on RS485: (this is in HEX mode)
but I get this on MAX485 output:
  • I use USBtoRS485 converter to log the rs485 data.
  • I've tried some MAX485 ICs to make sure the reason is not the IC itself.
  • my microcontroller is STMH750
  • I use buadrate 9600bps , no parity, 8 data bits, 1 stop bit
  • the output of RS485 stops to work on buadrate 1200bps.
Would you please give me some solutions to find the reason and solve it?
    \$\begingroup\$ If you're converting from UART (TTL signal on DI pin) to RS-485, you need to enable the driver. You currently have it disabled -- the DE pin is pulled low. \$\endgroup\$
    – Dave Tweed
    Oct 9, 2022 at 11:34
    \$\begingroup\$ You need to add that information to your question, along with a lot more detail about the nature of the errors. It could be many things -- baud rate mismatch, something else driving the RS-485 lines, etc. \$\endgroup\$
    – Dave Tweed
    Oct 9, 2022 at 11:58
    \$\begingroup\$ The RO is connected to UART TX. That can't be right, connecting two outputs together. Which means RI and RX are two inputs connected together. \$\endgroup\$
    – Justme
    Oct 9, 2022 at 12:59
    \$\begingroup\$ In addition to the A & B pair, do you have a Ground wire connected between your circuit and the RS485-USB converter at your PC? \$\endgroup\$
    – brhans
    Oct 9, 2022 at 13:28
    \$\begingroup\$ Your received data looks like you might have the A & B pins reversed. Did you try swapping them over? \$\endgroup\$
    – brhans
    Oct 9, 2022 at 13:32
TX and RX is swapped and the floating input receives noise.
