I have a question about this page from this book - Design of Analog CMOS Integrated Circuits.
The author isn't being very clear on distinguishing what is small-signal and what is large-signal. In the point marked (1), a step is applied at Vin,CM. Is this small-signal or large-signal. From the point marked (2), I believe it should be a small-signal step since the author is using g_m for the gain. However, in the point marked (3), he is stating that bias points are affected.
I'm confused. Is the Vin,CM step supposed to be treated as small-signal or large-signal? If it is large-signal, then g_m cannot be assumed to be fixed?
Or is the author just using this to gain intuition and not being rigorous.
"Gain" is, almost exclusively, a small-signal parameter.
However, even if you think about large-signal behavior, what you should note is the overall magnitudes of the different parameters.
In most VLSI circuits, 1/(2gm) is quite a bit less than RSS which means that the common mode gain is roughly proportional to RD/RSS. Designers tend to make RSS greater than RD, so the common mode gain is fairly insensitive to even large-signal changes (until the transistors drop out of saturation) as the common mode gain is less than 1 (generally by quite a bit).
Compare this to the differential gain which is proportional to -gm * RD which is quite a bit more sensitive large-signal features.
Hope this helps.
