-1
I have three 2000 mAh, 3.7 V Li-ion pouch cells.
I want to connect these three cells in series to get 11.1 V and 2000 mah
I made 11.1 V out of three Li-ion cylinder cells before; I used a BMS.
bms
As my project now needs a small, compact battery, I want to DIY a 3s, 11.1 V Li-ion battery pack with pouch cells.
Can I connect the Li-ion pouch cells in series with a BMS to get 11.1 V, in the same way as with the Li-ion cells?
If yes, can I use a block adapter to recharge it?
    \$\begingroup\$ If you connect three Li-po cells with the same capacity and at the same state of charge, and use a 3S balancing BMS, you can build a good and safe battery pack. You can't just connect a power supply for charging, though. You will still need a proper 3S Li-po charger to charge the battery pack; the BMS is not a charger. \$\endgroup\$
    – ocrdu
    Oct 10, 2022 at 7:54
Assuming the second picture is this amazon battery protection board, it should work with Li-Po Cells as well as cylinder cells.
As @orcdu says, you will need a separate charger. Something like this should work, however you will need to get a 3s balance connector to connect the individual cells to the balance output. Connect the output to P+ and P- of the BMS and wire the balance connector like this:
What you call "Lipo" are actually Li-ion cells in a pouch package. Internally, they are Li-ion cells regardless of whether they are housed in a plastic pouch or a metal cylinder. Therefore, as long as they have the same voltage (in this case, 3.6 V nominally), they work the same regardless. That BMS will work with them the same, because, whether they are housed in a plastic pouch or a metal cylinder, these cells act the same.
