I am building a simple volume control surface using an Arduino plus a few potentiometers (slide and knob). I am following the guide found here.
Essentially this is the guide for wiring everything up:
I followed it all exactly as it is above and when I starting testing the sliders connected I found this: Sliders connected to A1, A2, A3 and A4 are working exactly as expected when observing them in the serial monitor. However when I move the slide on A0 it changes the value for itself (A0) and A1. Below is screenshot of serial montinor with values shown for pins A0 - A4 from left to right (not only slider A0 is turned up physically):
I tried using a different set of pins on the Arduino, from A3 - A7, same issue.
Here is how I have hooked it up:
- I paid close attention to connect 5V to all the tabs marked "1" in on my slider pots and the data pins are hooked up to the tabs labelled "2".
- Ground connected to all tabs marked "3"
- Although its hard to see on the photo, The ground wire does go across all the way at the bottom and there is a connection from the rotatory potentiometer's ground (left tab) to the common ground wire.
Parts I used:
- https://za.rs-online.com/web/p/potentiometers/7377795
- https://za.rs-online.com/web/p/potentiometers/2499238/
I use this simple code to program the Arduino and monitor the values changing as I'm adjusting the sliders.
Could it be that my Arduino is a bit defective or my pins are bridged somehow? I did hook it up wrong the first time cause I followed the photo and did not pay attention to the labels on the sliders and only noticed the ones I bought has the pins 1 and 2 flipped. But I doubt that will have caused damage.
