I am trying to compare theory vs simulation values and it seems to be that there are differences. I am using Multisim to simulate a RLC circuit, the LC are in parallel and in series to the resistor.
The circuit is given, enter image description here In the practical I used a function generator with an amplitude of \$10 V_{\text{pp}}\$ (5V to -5V). Now that I am working on the theory part, I used the maximum value as the magnitude to get the correct voltage, however I keep getting wrong phase shifts.
The parallel components impedance is \$Z=218j\$
Applying the voltage divider rule... \$V_{R_{1}}=\frac{R_{1}}{Z_{1}+R_{1}}V_{in}\$
\$V_{R_{1}} = (0.75\angle-41^{\circ})(5\angle0)= 3.76\angle-41^{\circ} \text{V}\$
The oscilloscope show's a different angle,
enter image description here This shows that VR1 lags Vin.
\$\theta = (2.66\cdot10^{-3}\cdot50\cdot360^{\circ}) = 48^{\circ}\$
When is the magnitude of input voltage phasor 10Vpp and when is it just the maximum 5Vp? Why am I getting big difference in phase shifts (48 compared to -41)? Thank you for taking the time.
    \$\begingroup\$ Have you considered that your inductor might not be that accurate; it could be maybe 20% different to what is marked on the component. You clearly are not using the precise peak tops of the waveforms. More care needed is my impression. \$\endgroup\$
    Oct 10, 2022 at 17:21
    \$\begingroup\$ The inductor will also probably have significant series resistance; 650 mH is quite a lot. That will throw things off as well (though not by too much). I recommend also using the zero crossings instead of the peaks, if you must use the cursors manually instead of a measurement function, as those are less difficult to line up your cursors on. \$\endgroup\$
    – Hearth
    Oct 10, 2022 at 19:37
  • \$\begingroup\$ When the green wave is too late versus red, phase is not "negative"? \$\endgroup\$
    – Antonio51
    Oct 10, 2022 at 20:50
Check this Maple sheet and picture.
When the sine is "too late" versus the generator, the phase is negative.
Is it?
As pointed out by @Hearth
With your data, the serial resistance of the inductor should be ~ 117 Ohm.
Calculate 20*log10(3.753/4.960)= -4.88 db.
Do AC analysis (parameter rr, serial resistor). At 50 Hz, just read this value and rr.
If you make a larger analysis, you should have this (guess: min @ 200 Hz).
