I believe it is either an inductor or a diode, but I'm not sure where else to begin. The voltage ratings are either 5VDC or 12VDC, and 28VDC was mistakenly applied to the PCB header. No smoke or anything was witnessed; however, when looking at the component with a thermal cam, this component heats up rapidly. Any ideas on what this component is?
Dimensions are 1.60mm long, 1.00mm wide, and 0.50mm tall
I did some research trying to find the specific package as well, but no such luck. Thank you all for your time.
