We have a high-current industrial machine rated for 3-phase at 230 V; the nameplate literally says "PHASES: 3Ph + PE", "VOLTAGE: 3X230VAC", and "FULL LOAD: 92A".
There are only three input terminals (neglecting the PE, which is attached to the machine's metal casing), so it must be a three-wire delta input (please correct me if that's inaccurate).
There is a 600 V 3ph service coming into the building (also only 3 conductors), and a transformer is needed to reduce the voltage for the machine. I believe a good match would have 600 V delta-input, and 230 V delta-output, but it seems delta-delta transformers are difficult to find, and that delta-input-wye-output transformers are far more common, at least in the size we need (using "standard" sizes, 45 kVA or larger, based on 230 * 93 * sqrt(3) ~= 37 kVA).
In any case, a [used] transformer was selected, and I'm not sure it's properly suited. The vector diagram on the nameplate indicates that it's a delta-input-wye-output, and the nameplate also claims "H.V.: 600V" and "L.V.: 220V". Because there is generally a bit of wiggle room with voltages, and because the transformer has taps (on the input side), we aren't too worried about under-voltage (i.e. 220 V isn't a showstopper, despite the target device being rated at 230 V), and the machine's manual suggests anywhere from 208 to 240 V is acceptable.
We had the transformer hooked up to the 600 V service, and took some measurements while it was not yet connected to the machine. On the input side (coming from the utility company), we measured ~615 V on all line-to-line combinations (with only a few volts of difference between the different phases), so the input is a little high, but that seems common when there's no real load, and as mentioned, there are taps, so we can adjust if needed.
What surprised us was the output side... line-to-line, we measured ~450 V, and line-to-neutral, we measured ~260 V (again, with a small bit of variation between the phases, but nothing significant). I can't see how this concurs with the nameplate stating "L.V.: 220V".
Another detail: the transformer's nameplate also has an unlabeled field stating, verbatim, "X1-X2-X3---- 220V" (four hyphens and four spaces before the "220V")... and I don't know what to make of such a marking. Is that suggesting the line-to-neutral voltage is 220V? Or line-to-line?
Finally, we measured the voltage between [output] neutral (X0) and ground (tied to the casing), and although one might expect it to be zero (if neutral -- X0 -- and ground are actually connected), we measured ~1.4 V.
We stopped at this point, because if the machine wants 230 V line-to-line, and we were measuring ~450 V on the transformer's outputs, there's a good chance we could damage the machine if it were connected.
I'm bewildered by the transformer nameplate values, versus the measurements we took. Why would the output we measured exceed the nameplate value by nearly 20% (line-to-neutral) or 105% (line-to-line)? How likely is it that the nameplate is inaccurate, or the transformer is internally miswired or defective? Also, what's the deal with the small-but-non-zero voltage between X0 and ground?
Last, but perhaps most important, supposing we had a transformer that was a better match (e.g. one rated with output "230Y/133"), would we be able to simply ignore the neutral output lug (X0) and connect the three lives (X1, X2, X3) to the machine, and be done with it? I believe so, but with the proviso that the phase loads need to be balanced. The machine has some sub-devices that use a lot of current (heating elements) but according to the schematics, they seem to be wired in a balanced fashion.
Yep, it's a wall-o'-text, but thanks in advance for any insights about using a wye-output transformer with a machine that has no neutral terminal, and how to be sure we have chosen the right transformer.
And yes, this existing question -- Driving a Delta Load with a Wye -- seems to suggest the answer to my question is simply "yes"... but I was hoping to get a bit more detail.
Addendum: I forgot to mention that each of the transformer's coils has two terminals on the secondary side, so the first coil has X1 and X4, the second coil, X2 and X5, and the third, X3 and X6. We measured line-to-line and line-to-neutral for the second set of terminals, with the hope that they represented an alternate output voltage if used instead of X1,X2,X3 ( kinda like output-side taps, not sure if that's even a thing ), but I can't recall the values. :-/ I think they were the same as or similar to the first set.
UPDATE: I had been suspecting this, but finally, I've received confirmation: the nameplate ( which was damaged, and got replaced ) is not accurate; it isn't a 600-to-220 ( line-to-line ) transformer after all ( confirmed with OEM ). And that explains why we were having a problem with it! Once again, thanks to everyone who commented / answered.
