I want to program a pic microcontroller, specifically, the PIC16F886. I am not experienced with programming PIC microcontrollers, however, after searching, I was able to find that you can program this with an Arduino, as ArduinoISP.
However, in order to do that, the PIC microcontroller has to support Low Voltage programming (LVP).
I saw this reference that says how to check if the microcontroller you want, can support LVP: https://microchipsupport.force.com/s/article/How-to-check-if-a-device-has-Low-Voltage-programming-LVP
It says to:
- Check "MEMORY PROGRAMMING SPECIFICATIONS" the levels of the MCLR/VPP and VDD pins.You can verify if they are the same or different and also refer to the AC/DC characteristics.
- Another thing to look in is the Programming Specification document of the device at the "Entering ICSP Mode" section.
I found the datasheet for this pic microcontroller located here: http://ww1.microchip.com/downloads/en/devicedoc/41291d.pdf
However, after searching the document for the strings "MEMORY PROGRAMMING SPECIFICATIONS" or "Entering ICSP Mode", I found nothing.
After searching for the strings "MCLR/VPP" I had 16 results and the string "LVP" gives me 2 results. However, I was unable to understand if this device supports Low Voltage Programming mode.
Does the PIC16F886 support LVP mode?
