I am playing with a Xilinx Spartan-3A development (XC3S50A-TQ144C) and then I tried to implement RS-232 serial port by following the guide here: http://www.fpga4fun.com/SerialInterface.html
I bought a DB-9 port and connect RxD,TxD,GND of DB-9 port to three pin of my development board. (Of coz GND is connect to the GND of my board)
I tried to send a signal of one character every second from the pin to TxD. I checked the signal with a scope. The signal should be correct.
But I cannot see any character shown on my terminal by reading from /dev/ttyS0 (Serial port on Linux).
The scope show that the signal is sent using +2.5V and -2.5V respectively. I think the problem is that serial port should be sent with at least +5V / -5V. How can I modify the board (or construct an amplifier circuit) to send signal in higher voltage?
I have a photo capture of my scope here:
  • \$\begingroup\$ Did you verify if the serial port on your PC works? \$\endgroup\$ – jippie Mar 30 '13 at 12:59
  • \$\begingroup\$ I cannot fully confirm as I do not have any serial port hardware now. But I connected RxD to one of my LED in the configuration. When I open /dev/ttyS0, I can see the signal of RxD change. I also tried with another USB to Serial port connector too. \$\endgroup\$ – wonghang Mar 30 '13 at 13:02
  • \$\begingroup\$ Have you got Tx (on your dev board) connected to Rx (on your pc)? \$\endgroup\$ – Andy aka Mar 30 '13 at 13:05
  • \$\begingroup\$ There is no TxD (or serial port) on my development board. They are just custom pin for me to program. I am building a serial port from scratch. \$\endgroup\$ – wonghang Mar 30 '13 at 13:07
  • \$\begingroup\$ What RS-232 interface are you using? Have you checked that is working properly? \$\endgroup\$ – Leon Heller Mar 30 '13 at 13:20
  • Look up the voltages for RS-232, your 2.5v logic is nowhere close. 5v and sometimes 3.3v logic may work to a degree, but is out of spec.
  • RS232 serial is inverted (traditionally in the level translator chip) from the sense of logic level serial.
  • if you connected an RS 232 output to your fpga without a level translator you have likely damaged it.
  • it is unlikely that you are getting -2.5v out of your fpga, rather this sounds like a measurement or description error.
In summary you need a level translator.
| improve this answer | |
Chris is right, if you want to connect your FPGA to a serial port of any kind, you need to have a proper RS232 driver like the MAX3232 or similar. Just like this from Pantech Solutions:
