I am currently building a private design project. For this I need an ESP12E. I try to get it running with only 3.3V (VIN on schematics). In addition, I would like to be able to program the chip later via TX/RX with a USB adapter. Since I had so far some failed attempts with boards, I would like to ask now first of all whether this time everything is correct or I have built in errors: enter image description here
On J1 there will be some devices and transistors later, but I want to build it slowly up to fix errors for debugging reasons :)
I thank you already once warmly for answers!
P.S.: If someone wants to have a look on the PCB too: enter image description here
EDIT, here is the new PCB: enter image description here (Just updated PCB after comments; 3.3V line 1.5mm; data lines 1.0mm; GND area on the bottom with VIAs; looking better?)
    \$\begingroup\$ Those are some narrow traces! \$\endgroup\$
    – Tyler
    Oct 21, 2022 at 15:43
  • \$\begingroup\$ The edit misses sone traces, are they on the bottom? Can you show them? Ground preferably is solid without too many/long interruptions. I would have cut the pcb just above R1/J2. Do you need screwholes? Put a ground via next to every signal via, as close as possible. \$\endgroup\$
    – RemyHx
    Oct 23, 2022 at 4:40
There needs to be wider traces for power and ground. Traces are resistors and the thicker they are the less resistance and inductance they have. More resistance and inductance means a voltage drop when the load (microprocessor) uses more current.
The ground needs to be a lot thicker (as thick as you can get it), it might be better to put a ground on the bottom layer and use vias to go to the top layer.
Grounds need to be very low resistance and inductance and not daisy chain loads (use a fill or use the entire bottom layer).
  • \$\begingroup\$ Ah okay I'll do that. But the schematics looks right? Why easyEDA uses this small traces aa standard setting? Just curious \$\endgroup\$
    – dessi
    Oct 21, 2022 at 17:19
    \$\begingroup\$ It's the responsibility of the designer to determine trace size. Schematics look ok \$\endgroup\$
    – Voltage Spike
    Oct 21, 2022 at 19:35
  • \$\begingroup\$ Just updated the PCB; should look/work better now? :) \$\endgroup\$
    – dessi
    Oct 22, 2022 at 8:23
    \$\begingroup\$ If the blue shading is a ground plane, better remove it from the module antenna area. More VCC decoupling is good, preferably add 100 uF or so. \$\endgroup\$
    – Wirewrap
    Oct 22, 2022 at 18:33
  • \$\begingroup\$ Thanks for the advise @Wirewrap \$\endgroup\$
    – dessi
    Oct 22, 2022 at 23:27
