What is the name of this battery connector?
This is the link to the battery itself.
    \$\begingroup\$ I'd would just cut the connector off and replace it with a connector I actually wanted to use. You're going to have to put a connector on whatever the battery is plugging into anyways. When cutting through battery wires CUT ONE WIRE AT A TIME!!! Or else you will produce a dangerous short circuit. \$\endgroup\$
    – DKNguyen
    Oct 23, 2022 at 17:27
    \$\begingroup\$ Fit your own connector - a common sense solution. \$\endgroup\$
    – Solar Mike
    Oct 23, 2022 at 18:35
It looks like a molex connector. You'll have to find the pins for it. Here is a link: https://www.molex.com/molex/products/part-detail/crimp_housings/0003091022
