I executed the following code on vcs:
module test;
reg v,y,a,b,p,m;
  initial
    begin
      v = 1'b0;
      #5 y = 1'b1;
      fork
        #20 a = v;
        #15 b = y;
join
#40 v = 1'b1;
fork
#10 p = v;
begin
#10 a = y;
#30 b = v;
end
#5 m = y;
join
end
initial
  $monitor($time, "\n v=%b y=%b a=%b b=%b m=%b  p=%b \n",v,y,a,b,m,p);
endmodule
The console gives the following output:
Compiler version S-2021.09; Runtime version S-2021.09;  Oct 24 03:00 2022
 v=0 y=x a=x b=x m=x  p=x
 v=0 y=1 a=x b=x m=x  p=x
                  20
 v=0 y=1 a=x b=1 m=x  p=x
                  25
 v=0 y=1 a=0 b=1 m=x  p=x
                  65
 v=1 y=1 a=0 b=1 m=x  p=x
                  70
 v=1 y=1 a=0 b=1 m=1  p=x
                  75
 v=1 y=1 a=1 b=1 m=1  p=1
What's the significance of using the 'begin and end' statements in the second fork block?
A fork block executes all statements within it in parallel.
A begin block executes all statements within it in sequence.
Here is the 2nd fork block with different whitespace layout:
fork
   #10 p = v;
   begin
      #10 a = y;
      #30 b = v;
   end
   #5 m = y;
join
In this fork block, 3 threads are run in parallel (all 3 start at the same time):
  1. The 1st statement: #10 p = v;
  2. The begin block
  3. The last statement: #5 m = y;
The 2 statements inside the begin block run in sequence. The 1st statement in that block delays simulation by 10. The 2nd statement delays by 30, for a total of 40. b is assigned to v 40 time units after the fork starts.
Without the begin/end block, 4 statement would run in parallel. b would be assigned to v 30 time units after the fork starts.
