I am learning VHDL for a University course.
My code:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
 entity operations is
 Port (x : in STD_LOGIC_VECTOR ( 2 downto 0) ;s : in STD_LOGIC_VECTOR (1 downto 0) ;
 F : out STD_LOGIC_VECTOR (5 downto 0));
 end operations;
 architecture dataflow of operations is
 begin
F(5)<= x(2)and x(1) and s(1) and (not s(0));
F(4)<= (x(2) and (not x(1)) and x(0) and (not s(0))) or (x(2) and x(0)and s(1) and (not s(0))) or ( x(2)and x(1) and s(1) and s(0));
F(3)<= (x(2) and (not x(1)) and x(0) and s(1)) or (x(2) and x(0)and s(1) and s(0)) or ((not x(2)) and x(1) and x(0) and s(1) and (not s(0)));
F(2)<= (x(2) and (not x(1)) and s(0)) or (x(2) and(not s(1)) and (not s(0))) or ((not x(2)) and x(1) and x(0) and s(0));
F(1)<= (x(2) and(not s(1)) and (not s(0))) or (x(1) and x(0)and (not s(1)) and ( not s(0))) or
((not x(2)) and (not x(1)) and x(0) and(not s(1)) and s(0)) or ((not x(2)) and x(1) and (not x(0)) and s(0))
or (x(1) and (not x(1)) and (not s(1)) and s(0)) ;
F(0)<= (x(2) and(not s(1)) and (not s(0))) or ((not X(0))and s(1) ) or (x(1) and (not s(0)) and (not x(0)))
or ((not x(2)) and (not x(1)) and x(0) and s(0));
 end dataflow;
Test bench:
library IEEE;
entity testbench is
--  Port ( );
end testbench;
architecture Behavioral of testbench is
component operations
 end component;
 --INPUTS
signal x: std_logic_vector ( 2 downto 0);
signal s: std_logic_vector ( 1 downto 0);
signal F: std_logic_vector(5 downto 0);
begin
uut: operations port map(x=>x,s=>s,F=>F);
Stim_proc: process
begin
      x<= "001";s<="00"; wait for 100ns;
end process;
END;
The x, s, and F values are U constantly.
  • \$\begingroup\$ Is the waveform diagram looking at the signals in the testbench level or on the dut level? I also noticed that you put the architecture of "operation" to "dataflow" while the test bench is "behavioral". These usually need to match. \$\endgroup\$
    – pknodle
    Commented Oct 24, 2022 at 20:23
  • \$\begingroup\$ testbench level and even when i try using another component implemented using behavioral it gives the same output \$\endgroup\$
    – Nour Samir
    Commented Oct 24, 2022 at 21:03
Make sure you zoom the wave form:
Looks fine here (also using Vivado). Adding a wait at the end of the process blocks the simulation. You should also avoid the 2 non-standard libraries.
library IEEE;
entity testbench is
end testbench;
Port (x : in STD_LOGIC_VECTOR(2 downto 0);
      s : in STD_LOGIC_VECTOR(1 downto 0);
      F : out STD_LOGIC_VECTOR(5 downto 0));
end component;
signal x: std_logic_vector(2 downto 0);
signal s: std_logic_vector(1 downto 0);
begin
    Stim_proc: process
    begin
        x<= "001";s<="01"; wait for 100ns;
        x<= "000";s<="01"; wait for 100ns;
        x<= "000";s<="00"; wait for 100ns;
        wait;
    end process;
END;
