I'm currently working on a capacitance model which will be part of a greater compact model for a planar RFET.
I use Sentaurus TCAD to generate capacitance data, which I use to understand the capacitance behaviour and to compare my model to. Looking at the capacitances in general and for simplification purposes using a MOSFET as a simple example the question arises how the capacitances are defined?
More concretly two sub-questions arise:
- Where does the capacitance lie? Can you think about the capacitance like a plate capacitor sitting between the terminals? If yes, what capacitance is \$C(g,g)\$ describing?
- Why are capacitances negative? Does it mean that the capacitance is really negative, or does this phenomena arise from the calculation or defintion of the capacitances?
The user-manual describes the capacitance matrix as the imaginary part of the admittance matrix divided by the circular frequency (nu being the excitation frequency): \$Y=A+i2\pi\nu C\$
The admittance matrix is calculated by dividing the small signal current excitation vector with the small signal voltage excitation vector: \$\delta I=Y\delta V\$
If that's the case is it even possible to attribute a specific location to the calculated capacitances? Like this for all capacitances connected with the gate?:
And maybe a negative current or a negative voltage explains why an admittance would be negative, but can this relation be transferred to the capacitance as well, which as the imaginary part can be negative for other reasons? There was already questions asked, why the capacitance is negative. In the answer, that \$C_{ij}\$ is \$C_{ij}\$ if \$i=j\$ and \$-C_{ij}\$ if \$i\neq j\$ (reference1), makes sense at first sight, but analysing a standard NMOS in TCAD (project: getting started/AC) at \$0.01Hz\$ shows, that \$C(s,d)=C(d,s) > 0\$, which would make sense if the capacitance itself is really negative (reference2). But negative capacitances seem only to show in transistors with ferroelectric materials, which is not the case for this NMOS.
Or is it like in Tsividis, Yannis (1999) on page 442 where this is written:
It will be helpful in this discussion not to associate the various capacitance parameters above with any physical capacitor-like structures in the MOS transistor.
I'm thankful for any input and I belive this can be an important discussion also for other people.
