I used the following code to send out an USART asynchronous transmission of a string "AT\n\r" using a PIC18F4550.
// PIC18F4550 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config PLLDIV = 5 // PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1 // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = HSPLL_HS // Oscillator Selection bits (HS Oscillator, PLL enabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = ON // Brown-out Reset Enable bits (Brown-out Reset enabled in hardware only (SBOREN is disabled))
#pragma config BORV = 3 // Brown-out Reset Voltage bits (Minimum setting 2.05V)
#pragma config VREGEN = OFF // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF // Watchdog Timer Enable bit (WDT enabled)
#pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = ON // PORTB A/D Enable bit (PORTB<4:0> pins are configured as analog input channels on Reset)
#pragma config LPT1OSC = OFF // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
#pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
#pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <pic18f4550.h>
#define _XTAL_FREQ 20000000
void USART_send_string(char *msg);
void main(void) {
TRISCbits.TRISC6 = 1;
TRISCbits.TRISC7 = 1;
BAUDCONbits.BRG16 = 0;
TXSTA = 0x24;
RCSTA = 0x90;
SPBRG = 25;
USART_send_string("AT\r\n");
while(1)
while (*msg != '\0')
while(TXIF == 0);
TXREG = *msg;
*msg++;
Based on the datasheet, as soon as the data from the TXREG register is transferred to the TSR register, the TXIF interrupt flag is set. So, the USART_send_string function is used to keep loading the TXREG register based on the TXIF flag as long as the string input is not "NULL" ("\0").
While this transmits the desired string "AT\n\r" correctly, upon closer inspection with the logic analyzer, it appears that the USART transmission is repeated continuously approximately around every 100 ms for no apparent reason, as shown below.
What could be the cause of this continuous transmission?
I have included the assembly listing of the code in case it is helpful in any way:
70: #include <xc.h>
71: #include <pic18f4550.h>
72:
73: #define _XTAL_FREQ 20000000
74:
75: void USART_send_string(char *msg);
76:
77: void main(void) {
78: TRISCbits.TRISC6 = 1;
084A 8C94 BSF TRISC, 6, ACCESS
79: TRISCbits.TRISC7 = 1;
084C 8E94 BSF TRISC, 7, ACCESS
80:
81: INTCONbits.GIE = 0;
084E 9EF2 BCF INTCON, 7, ACCESS
82: INTCONbits.PEIE = 0;
0850 9CF2 BCF INTCON, 6, ACCESS
83:
84: BAUDCONbits.BRG16 = 0;
0852 96B8 BCF BAUDCON, 3, ACCESS
85: TXSTA = 0x24;
0854 0E24 MOVLW 0x24
0856 6EAC MOVWF TXSTA, ACCESS
86: RCSTA = 0x90;
0858 0E90 MOVLW 0x90
085A 6EAB MOVWF RCSTA, ACCESS
87: SPBRG = 25;
085C 0E19 MOVLW 0x19
085E 6EAF MOVWF SPBRG, ACCESS
88:
89: USART_send_string("AT\r\n");
0860 0E01 MOVLW 0x1
0862 6E01 MOVWF __pcstackCOMRAM, ACCESS
0864 0E08 MOVLW 0x8
0866 6E02 MOVWF 0x2, ACCESS
0868 EC04 CALL 0x808, 0
086A F004 NOP
90: while(1)
91: {}
086C EF36 GOTO 0x86C
086E F004 NOP
0870 EF00 GOTO 0x0
0872 F000 NOP
92: }
93:
94: void USART_send_string(char *msg)
95: {
96: while (*msg != '\0')
0808 EF16 GOTO 0x82C
080A F004 NOP
082C C001 MOVFF __pcstackCOMRAM, TBLPTR
082E FFF6 NOP
0830 C002 MOVFF 0x2, TBLPTRH
0832 FFF7 NOP
0834 0008 TBLRD*
0836 50F5 MOVF TABLAT, W, ACCESS
0838 0900 IORLW 0x0
083A A4D8 BTFSS STATUS, 2, ACCESS
083C EF22 GOTO 0x844
083E F004 NOP
0840 EF24 GOTO 0x848
0842 F004 NOP
0844 EF06 GOTO 0x80C
0846 F004 NOP
97: {
98: while(TXIF == 0);
080C A89E BTFSS PIR1, 4, ACCESS
080E EF0B GOTO 0x816
0810 F004 NOP
0812 EF0D GOTO 0x81A
0814 F004 NOP
0816 EF06 GOTO 0x80C
0818 F004 NOP
99: TXREG = *msg;
081A C001 MOVFF __pcstackCOMRAM, TBLPTR
081C FFF6 NOP
081E C002 MOVFF 0x2, TBLPTRH
0820 FFF7 NOP
0822 0008 TBLRD*
0824 CFF5 MOVFF TABLAT, TXREG
0826 FFAD NOP
100: *msg++;
0828 4A01 INFSNZ __pcstackCOMRAM, F, ACCESS
082A 2A02 INCF 0x2, F, ACCESS
101: }
102: }
0848 0012 RETURN 0
*msg++;
is nonsense (it will work here but likely produce warnings). It should bemsg++;
instead. \$\endgroup\$
