My aim is to find the pulse width of an unknown incoming signal. To that I have written the following synthesizable verilog code but I am getting the warning XST 1710 and XST 1895. When I try to simulate the code, I get 'XXXXXX' in red.
Top module:
`timescale 1ns / 1ps
module top( input clk_100mhz,
input inp,
input reset,
output [13:0] average
wire [13:0] w_width;
wire [13:0] w_sum;
pulse_counter pc(.clk_100mhz(clk_100mhz),
.inp(inp),
.reset(reset),
.width(w_width));
adder a(.width(w_width),
.sum(w_sum));
averager avg(.clk_100mhz(clk_100mhz),
.reset(reset),
.sum(w_sum),
.average(average));
endmodule
Pulse Counter Module:
module pulse_counter( input clk_100mhz,
input inp,
input reset,
output reg [13:0] width
reg [13:0] counter;
always @(posedge clk_100mhz or posedge reset)
if (reset) begin
counter <= 14'd0;
end
else begin
if(inp == 1) begin
counter <= counter + 14'd1;
end
if(inp == 0) begin
width <= counter;
counter <= 14'd0;
end
end
endmodule
Adder Module:
module adder( input [13:0] width,
output reg [13:0] sum = 14'd0
always @(width) begin
sum = sum + width;
end
endmodule
Averager module:
module averager( input clk_100mhz,
input [13:0] sum,
input reset,
output reg [13:0] average
reg [27:0] counter;
always@(posedge clk_100mhz or posedge reset) begin
if (reset) begin
counter <= 28'd0;
end
else begin
counter <= counter + 28'd1;
if (counter == 100000000) begin
average = (sum + 14'd50) / 14'd100;
counter <= 28'd0;
end
end
end
endmodule
Warning:
WARNING:Xst:1710 - FF/Latch <avg/average_8> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <avg/average_9> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <avg/average_10> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <avg/average_11> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <avg/average_12> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <avg/average_13> (without init value) has a constant value of 0 in block <top>. This FF/Latch will be trimmed during the optimization process.
Test Bench:
module toptb;
// Inputs
reg clk_100mhz;
reg inp;
reg reset;
// Outputs
wire [13:0] average;
// Instantiate the Unit Under Test (UUT)
top uut (
.inp(inp),
.reset(reset),
.average(average)
initial begin
// Initialize Inputs
clk_100mhz = 0;
inp = 0;
reset = 0;
#10 reset = 1;
#10 reset = 0;
// Wait 100 ns for global reset to finish
#100;
// Add stimulus here
end
always #5 clk_100mhz = ~clk_100mhz;
always #10000 inp = ~inp;
endmodule
I have been stuck here for sometime now and I couldn't solve the issue. Would really be helpful if someone helped me in solving this issue.
