I don't know why I have a problem with compiling my Verilog code. I have these errors:
I have Icarus Verilog installed, and I checked it using the iverilog command. I also added the path for VSCode and for Iverilog.
Code:
`timescale 1ns/1ps
`include "not_example1.sv"
module testbench;
    parameter BITS = 4;
    logic [BITS-1:0] s_in;
    logic [BITS-1:0] s_model_outs;
not_example1     #(.NUM(BITS))   not_model    (.i_a(s_in), .o_y1(s_model_outs));
initial
    begin
        $dumpfile("signals.vcd");
        $dumpvars(0,testbench);
        s_in = '0;
        #1  s_in = '1;
        #1  s_in = '0;
        #1  s_in = '1;
        #1
        $finish;
    end
endmodule
This warning message tells you that you should use the option named -g2005-sv when you run the iverilog command:
testbench.sv: warning: Using SystemVerilog 'N bit vector. Use at least -g2005-sv to remove this warning.
Some Verilog syntax, especially for features added to SystemVerilog (IEEE 1800), requires you to use special iverilog options.
This command fixes the errors and warnings for me:
iverilog -o testbench.vvp -g2005-sv testbench.sv
I have this version of iverilog installed:
iverilog -v
Icarus Verilog version 10.3 (stable) (v10_3)
To see the iverilog command usage, use the -h option:
iverilog -h
Usage: iverilog [-ESvV] [-B base] [-c cmdfile|-f cmdfile]
                [-g1995|-g2001|-g2005|-g2005-sv|-g2009|-g2012] [-g<feature>]
                [-D macro[=defn]] [-I includedir]
                [-M [mode=]depfile] [-m module]
                [-N file] [-o filename] [-p flag=value]
                [-s topmodule] [-t target] [-T min|typ|max]
                [-W class] [-y dir] [-Y suf] [-l file] source_file(s)
See the man page for details.
Also refer to the Icarus Verilog User Guide
