I have been designing a circuit to filter noise from an ECG signal and amplify the signal of interest.
I am achieving this by cascading the output of an instrumentation amplifier with a bandpass filter and then a notch filter.
The AC analysis of the circuit is providing a result as desired, but the transient analysis is consuming a lot of time with no output.
Could someone please tell me what the required changes in the circuit would be to get an output?
    \$\begingroup\$ The problem is most likely in this mess, which I am not sure I can even read. You might add your netlist here so that I can figure it out. Or else redraw that mess. Once I can see what's connected to what, I think the issue will be clearer. In the meantime, why not simply remove all that stuff over there -- just temporarily (you can use shift-F9 to restore it) -- and see if the simulation runs better. \$\endgroup\$
    – jonk
    Oct 30, 2022 at 19:25
    \$\begingroup\$ @jonk OP also has no time domain signal sources, they're set for .ac, so OP needs to decide which one is it: .tran with a proper signal, or .ac (with the rather strange two AC sources). Also, the suuplies, as Jonathan S. said. \$\endgroup\$ Oct 30, 2022 at 19:26
    \$\begingroup\$ @jonk Yes, no DC value translates to a zero (it can make current sensors a bit friendlier to the eyes with no value). Likely not what OP wants. :-) \$\endgroup\$ Oct 30, 2022 at 19:29
    \$\begingroup\$ @aconcernedcitizen True. But it wouldn't cause the simulation to drag on, either. \$\endgroup\$
    – jonk
    \$\begingroup\$ @jonk Yes, I just tried now a simple noninverting amplifier (with 50k/1k feedback) and +/-100 V supplies: the simulation is stuck on finding the operating point. Pressing Esc to cancel the four algorithms results in an error (failed to find op pnt ...). So the internal power supply limit does hurt the simulation. I just checked the subcircuit and it's not made with the OTA+MOSFETs (the LTspice way), it's with bipolars and POLY sources. That may be a clue. Or not. At any rate, with +/-15 V supplies it takes off instantly. \$\endgroup\$ Oct 30, 2022 at 19:42
LTSpice is having trouble finding the circuit's operating point, which isn't that surprising given that you're operating your opamps with 200V supply voltage. The OP747 can take at most 36V. Lower your supply voltages to +/-15V or so.
Your simulation command (.tran) is also a little odd. Try .tran 1 with no other parameters.
Your signal sources are also 0V in a transient simulation, but that shouldn't prevent LTSpice from simulating it in the first place. You might want to enter a sine signal there, though.
    \$\begingroup\$ The .tran card is not wrong, it just doesn't make sense to have a timestep that is 10 times smaller than the total simulation time (default is around 1000x). LTspice will likely ignore the 0.1. The supply is wrong, though. Also, there is no .tran signal in the sources (at least nothing visible), they are set to .ac analysis: either use a time domain signal for .tran, or switch to an .ac card. \$\endgroup\$ Oct 30, 2022 at 19:22
    \$\begingroup\$ @aconcernedcitizen You're right, I wrongly thought that the stop time comes first. Edited accordingly. \$\endgroup\$ Oct 30, 2022 at 19:26
C5 looks like it's shorted, this will cause problems with the solver. If that isn't it then it's probably the loading network on the output of C5. If that is the case put an impedance buffer between C5 and the loading network (filter)
It could also be the op797 model.
    \$\begingroup\$ shorted capacitors don't cause SPICE solver problems. \$\endgroup\$
    – jp314
    Oct 30, 2022 at 22:55
