I need help with my project. I want to split a pulse on the timeline. I want to take the signal and divide it by 58 μs. Actually the time of the output signal is not important. I just need to generate (input pulse time length) / (58 μs) signal on output. A few people said you can use a clock, but I haven't used clocks other than microprocessors before, how can I use them exactly? If I directly connect the signal to input leg of the clock, can I get a signal from the output divided by frequency as I want? I'm sorry, if it's a stupid question. I'm sure there's a very simple answer and there's a term for it, but I don't know much about it. I've added a picture to make it more descriptive. Sorry for the bad drawing. The upper pulses represent the input, and the lower ones represent the pulses I want to receive at the output.
edit: I can't use microprocessor.
