As above.
This is my guess but need some expert input.
Violet+grey on the primary. Black+yellow the secondary.
Thanks
As above.
Thanks
If you have a 120V supply, then it is Hot to brown/gray. Neutral to violet/blue.
If you have a 220-240V supply, then you splice violet and gray only to each other. And then, hot to brown and neutral to blue, as usual.
You haven't said anything about what you want. I'm going to give you North American style "twice the secondary voltage with a center-tap", as might be used with a half-wave rectifier. So in that case you tie together black & yellow to be your center point. Red is now your pole L1, and orange is your pole L2. It's AC so it is not the case that red is + and orange is -. It is half the time.
