I'm trying to understand the operation of opamps, especially how to amplify a voltage as illustrated in the images from a (for example) photoelement so these can be used a the following comparator.
One circuit I found and seems to be working in their model is here - circuit A from this webpage:
TI E2E forum - "OPA858: Amplifier for Fast and Standard output of Silicon Photomultipliers"
I'm currently using LTSpice (since that's what I'm most familiar with) but it doesn't supply the OPA858 or OPA656 opamps. Are there any comparable opamps I can use in LTspice? The aim is to understand and get a circuit that amplifies a simple small voltage to be processed by a comparator.
About the circuit (A) above, a small voltage to the opamp here (30mV) gives an output voltage of approx. 1V at V_amp. I've tried numerous times to do something similar with different opamps in LTSpice, but it doesn't work... I never get any amplification of the initial signal.
Can someone help me understand I could get a low voltage signal like the above (30mV) with an opamp amplified that in the end it can be used for further processing?
Here is my circuit in LTSpice:
Additionally, I tried another circuit which is in the opamps (LTC6268) datasheet - not working as well:
