I have a seemingly simple problem.
I am developing a system that harvests energy from a piezo-electric vibration source. The harvesting circuit works well and I am happy with that, but I also want to use the vibration source as a sensor to measure vibrations, and the harvester is interfering with that because it draws a current from the high-impedance source, distorting the signal from the vibration.
I thought to include a switch before the harvester circuit so that I can switch it off from a microcontroller temporarily, disconnecting the harvester from the source. The concept is depicted in the diagram.
The question is now, how to implement this.
The difficulty lies in:
- the unknown voltage level at the source input
- the relatively low voltage at the output of the MCU (1.8 V)
- the requirement that the switch must be closed when the MCU is off, as the harvester needs to be able to cold-start the system
I came up with a somewhat complicated solution, using a depletion mode JFET, that cuts off the voltage if the gate-source voltage is positive. This still has the drawback that, as I see it, the JFETs have a fairly high on-resistance if VGS is zero (around 200 Ω, which is very considerable for the harvesting application).
Furthermore, I need two additional transistors to achieve the highest possible Vgs, when I want to switch the JFET off.
Am I missing some easier solution here? It seems like a not-so-uncommon problem to me, but I couldn't really find something fitting here. Are there ICs that you know of that would serve the purpose?
