How to identify female power connector with 2 pins, 1.00 mm pitch? Is it JST SH connector?
Picture of the connector:
    \$\begingroup\$ Looks like it might be 1.27mm . \$\endgroup\$ Commented Nov 7, 2022 at 20:47
  • \$\begingroup\$ definitely more than 1.0 mm \$\endgroup\$
    – jsotola
    Commented Nov 7, 2022 at 21:14
    \$\begingroup\$ "Is it JST SH connector?" No, it is not. \$\endgroup\$ Commented Nov 7, 2022 at 22:07
  • \$\begingroup\$ @TomCarpenter You are right. Is 1.27mm or 1.25mm. \$\endgroup\$ Commented Nov 8, 2022 at 21:24
This is a Molex PicoBlade connector.
  • \$\begingroup\$ That is 1.25 mm pitch. Strange that it is not the more standard 1.27 mm (0.05"), but should not matter for just two pins, and probably up to 4 or 5 before it would be an issue. But I think most small connectors like this have round pins, and not blades. \$\endgroup\$
    – PStechPaul
    Commented Nov 7, 2022 at 23:24
  • \$\begingroup\$ You identified it! Thank you. \$\endgroup\$ Commented Nov 8, 2022 at 21:25
