I'm currently trying to build an inverting op-amp with single 12 V supply for audio applications.
The circuit below is the one that worked super well with 12-0-12 (had low noise and low distortion), and now I want to convert it to a single-supply amp with inverting input.
I'm very new to op-amps and couldn't figure out a satisfactory solution on how to do so.
  • \$\begingroup\$ It all depends on how much power you want on the output. ±12V = 24Vpp. Whereas 0-5V = 5Vpp (peak to peak). That won't be very loud. \$\endgroup\$
    – Aaron
    Nov 8, 2022 at 17:16
  • \$\begingroup\$ Why don't you use a negative supply generator circuit. \$\endgroup\$
    Nov 8, 2022 at 17:19
    \$\begingroup\$ Perhaps you could consider the LM386 audio amplifier. It works with a single supply, and requires very few parts. \$\endgroup\$
    – ee_student
    Nov 8, 2022 at 17:37
  • \$\begingroup\$ @Aaron 12Vpp in my case is enough \$\endgroup\$
    – Marvin W
    Nov 8, 2022 at 18:39
  • \$\begingroup\$ @Andyaka well I'm trying to build a very compact amplifier and a center tapped transformer with rectifier etc would kinda defy the purpose of my design \$\endgroup\$
    – Marvin W
    Nov 8, 2022 at 18:40
Take a look at this example
So all you need to do is add a voltage divider (R2, R3) and C1, C2 capacitors to your project.
Or the inverting version
  • \$\begingroup\$ The op wants an inverting amplifier. \$\endgroup\$
    Nov 8, 2022 at 18:13
  • \$\begingroup\$ @Andyaka Oops, I didn't notice this. \$\endgroup\$
    – G36
    Nov 8, 2022 at 18:34
  • \$\begingroup\$ Thank you, so I just connect the non-inverting input to the divider and the input to the feedback loop? What would happen with R3, R5 and C5 from my schematic? \$\endgroup\$
    – Marvin W
    Nov 8, 2022 at 18:43
  • \$\begingroup\$ @MarvinW Yes, exactly you need a voltage divider at non-inverting input plus some large bypass capacitor. And the input via coupling capacitor (C3) to R7 (in your schematic). R5 and C5 are not needed in inverting configuration. And use R3 as a pull-down resistor for the C3 capacitor. \$\endgroup\$
    – G36
    Nov 8, 2022 at 19:05
  • \$\begingroup\$ Okay will try that, thank you very much for your help \$\endgroup\$
    – Marvin W
    Nov 8, 2022 at 19:08
